vapman
Member of the Trade: bhobuds.com
- Aug 14, 2006
^ Should do fine sound wise. I have a sanyo os-con on the way for power cap. I just hope they hold up without leaking because supposedly it's important to de-rate organic polymer caps more-so than other electrolytics and using 16v for power cap where walnut is putting out 15-16v, is risky, really should be using 25v.
The issue with walnut is that nearly no good audio caps will fit in the 1000uf 25v size. Also organic poly's don't come in high voltage/uf anyway, you will have to drop down to 680uf to get a 25v, but this is actually fine, due to organic poly's higher conductivity and lower ESR essentially means you can get away with much lower capacitance for the same task, eg a 330uf would probably suffice as the power cap I believe, but why not just go with 680uf 25v for kicks.
If a 680uf works that would be great and make it able to fit in there. yeah, true that running a 16v cap at 16v is a little sketchy... I haven't placed my order yet so i am on the fence if i am gonna get all 16v caps for psu or some 25v's. (figuring out if i need knobs too mostly)
