kin0kin
- Jan 4, 2005
connect the plug to the jack. put the +ve probe on the center pin/plate....it is very obvious as it branch out from the middle of the jack if you look from th rear. then just tap other probe on the washer and check if there is any measuring. if there is nothing, solder a wire to IG/PG, turn on your amp and confirm the buzz, tap the washer with your finger and check if the buzz disappear. if it does, tap it with the wire this time, and if it disappears, you know what to do
if it measures something when you tap the probe on the washer....don't connect it to IG/PG.
