krisjan
- Sep 27, 2008
I am new to the DIY stuff - but have decided to venture into this area - hoping to build my first amp (probably a cmoy) soon - i already purchased some equipment and 4 the moment i am just looking at an existing cmoy i purchased (eBay View About Me for biosciencegeek).
Ok so one of the issues in this whole amp is re the power supply source. After reading Op-Amp Power Supply Quality Considerations and also considering the obvious disadvantages of batteries (depleting and causing distortion) i decided to try wall-power to see if there are audible differences. I asked BSG re the wall-wart (on the site he recommends Regulated and Filtered Universal 300mA AC Adapter - RadioShack.com - is this one switch-mode?) since i live in ZA and obviously different shops here etc. He was very helpful but didn't mention that linear-regulated is the way to go for audio amps...so in the end i just took an existing ac/dc adapter intended for powering a handheld spotlight - specs 12V,300ma - i modded the plug, making sure of polarity, and tried it - it seemed great...if i turn up the volume very high (with no source coming in) i hear some noise, but this is identical to the noise with a 9v battery loaded, so doesn't seem as if (audibly) anything is added by the psu.
Then i read about the whole regulated/unregulated thing, i purchased a multimeter and did the measurements - the modded psu read much higher than the indicated spec value of 12v (about 17v) - so i suppose meaning it's unregulated...I went to the electronics store and tried to get a linear regulated psu - LOL the electronics "expert" in the shop didn't even know that you get switch-mode and linear - he didn't know what i was talking about, and i ended up buying a psu very similar to the one bsg recommends ( i think specs are exact) - it states it is regulated, but not what type. Now according to Op-Amp Power Supply Quality Considerations a good switch-mode could actually be acceptable - so i thought let me try it...result: MAN is it noisy! - i just switch the amp on and immediately there's hiss - even at low volumes - it's basically unusable - so i presume it must be aswitch-mode and then a BAD switch-mode in Op-Amp Power Supply Quality Considerations 's book...
So my q's are -
if i use an unregulated supply and i honestly can't hear any noise added - does it matter?
Could the increased voltage due to low load of the amp cause components to fail? I know the opamp (2227 in the bsg) can handle the 17v easy according to the spec, but maybe depending on the resistors/caps he used some of those might fail?
So my q's are -
