Hello everyone! I hope you are well.
I purchased this amplifier used, have demoed it at the person's house who sold it to me, they connected it in this way. HD800S -> Amp -> DAC (Chord Qutest) -> computer, which made it have zero noise whatsoever. Regardless of me changing the volume rapidly (which does create noise on my setup.)
Whenever I switch on my WA2 amplifier it seems to create lots of noise in form of 'hiss / electric noise' regardless of me not playing anything, even if I were to just plug in my headset without any output. Everything I've tried has not fixed the issue. I read that that OTL amps have an issue with constant noise. However, sometimes the noise goes dead silent and other times it gets louder than the music I play. (Not constant noise volume)
Currently connecting it this way.
Headset (primarily 1990 pro, hoping to use it on my Verite's) - > Amp > DAC (FIIO K11) *using optical cable and USB cable-> alternating between doesn't make a difference in noise* -> computer.
Things I've tried to eliminate noise:
- Isolating the power supply away from my computer. (still produces noise)
- Moving the entire amp away from the computer and into my laptop. (Still produces noise)
- Used multiple headsets of low and high impedance. (DT 1990, Audeze LCD2C *yes I am aware planars not the best idea for this amplifier*, among other headsets)
- Keeping all power supply cables into one extension cord from another wall.
- Turning off all lights, Bluetooth devices and mobile phones.
- Switching on the tubes and keeping them to warm up for 15-30 mins before playing anything on them and while are headphones connected (not sure if this makes a difference or not). (Manual stated one minute of warm is enough for it, still extended it for the sake of experimentation and no difference)
All attempts have not been fruitful, it has made little to no impact in terms of reducing/eliminating noise.
Everything I've tried was an amalgamation of many different 'solutions' others have tried in order to combat this 'problem' and I am out of options. If anyone has any idea what causes this it would surely drive away my current insanity from this noise.
Thank you for reading!
