Wolfster
- Jan 5, 2010
Hello, I am hoping this is the right place to ask for advice on how to fix my issue with my E3c ear-phones.
I purchased the E3C earphones a while ago. When I bought them were working fine. After using them only a few times this issue with the Left ear-phone began to happen. It seems to be noticeably quieter than the right, so much so that I cannot use them. I have tried cleaning the wax out of the ear-phone (with the tool provided) and blowing into the ear-piece but this hasnt worked. I am concerned that by trying to clean the wax from rubber tips(with Saliva) when I first used them, this has caused them to not work correctly. Im not sure what else can be done.
Also my E3c's dont appear to have wax guards. Is this normal?
Anyone have any suggestions? help would be very much appreciated.
kind regards,
Nik
kind regards,
Nik
