Volume control with a DAC/Amp
post-14386638
Thread Starter
Post #1 of 5
jbiribi
Brazil
Brazil
I want to buy a Topping D3 to use with my TV by optical cable. Using that way, I'll be able to control the volume with the TV remote controller too? Or only using the Topping D3 volume button?
post-14387133
Post #2 of 5
ProtegeManiac
Manila
Manila
Website
www.instagram.com
That depends on whether the TV allows for volume control on its digital output, and chances are, it doesn't. This is why HT receivers take a digital signal and then volume control is on the HD receiver. The ones we have can't control the volume when running digital output via HDMI ARC.
post-14387351
Post #3 of 5
jbiribi
Brazil
Brazil
The 3.5mm output can be controlled by the remote controller. Maybe the optical can too?
post-14387944
Post #4 of 5
technobear
Glastonbury, UK
Glastonbury, UK
post-14388807
Post #5 of 5
ProtegeManiac
Manila
Manila
Website
www.instagram.com
That is far from automatic. 3.5mm headphone output can be tied to the same amp circuit as the speakers and therefore volume control works. If the HDTV has no DSP chip that allows for volume control on SPDIF output then it can't work.
