olblueyez
Banned
- Jun 16, 2008
I fix computers for Telefunken ECC802S tubes. One computer in good working order = one ECC802S.
Originally Posted by chesebert /img/forum/go_quote.gif something else is taking up your drive space and those are not the restore points and shadow copies, since they are restricted to 3.859GB in your system. anything particularly wrong with your PC you haven't told us yet? |
Originally Posted by CDBacklash /img/forum/go_quote.gif Nope. Theres nothing wrong with the computer. I'll work it out and post solution |
Originally Posted by chesebert /img/forum/go_quote.gif hmm..ok. couple things we know 1) you are not that familiar with PC hardware diagnostic procedures and 2) it's probably better if you can take your computer to a professional to get it fixed. What brand is your PC? Regarding memtest, you have to download memtest86, burn it on a bootable CD, and boot your pc with the CD inserted; have memtest run multiple times (may take 2-4hrs). Report back, whether or not you have errors, when you have done that. If I were you I find a geek friend and get them to fix my computer. |
Originally Posted by scompton /img/forum/go_quote.gif Vista has been driving me crazy. Two nights ago, I installed a Windows update and went to bed. When I got home the next evening, the computer had been blue screening on boot up over and over all day. The blue screen cleared too fast for me to see what was causing it but I could boot into safe mode. I did a restore to before the update and that didn't fix it. I did a restore to a week ago and that didn't fix it, but after that restore, some program ran when I booted to safe mode that told me it was the video driver. Device manager said I had the latest driver so it would automatically fix it. I downloaded the latest driver from NVida and installed it and it didn't fix it. I downgraded to an old version of the driver and that didn't fix it. I gave up, powered off and went to bed. This morning, I powered it on and it booted fine. I've had the computer for 2 months and it's the second time it's blue screened. The other time, restore fixed it. I haven't had stuff like this happen since I was doing Windows development on NT 4. It's very frustrating |
Originally Posted by scompton /img/forum/go_quote.gif On board NVIDIA GeForce 6150 SE video I haven't installed any hardware Vista is the only OS I'll check the event log and remove the memory this evening. BTW, this is what I have and where I bought it HP Pavilion a6547c Refurbished AMD Desktop PC - AMD Athlon 64 X2 5000+ 2.6GHz, 4GB DDR2, 500GB SATA 3G, DVDRW DL Lightscribe, 15-in-1 Media Reader, Vista Home Premium 64-bit SP1 RB-HPKZ720AAR at TigerDirect.com |
Originally Posted by CDBacklash /img/forum/go_quote.gif *HDD space on C: is down a gig since last post. Might format earlier than expected... |
Originally Posted by odigg /img/forum/go_quote.gif You've probably got some software that switched on error logging and it is eating up all your free space. Before you reformat (and end up with the same problem after a reinstall) I suggest you try to figure out where the space is going. Check how big folders are. Start looking for the problem using your file/folder explorer. |
