Virtual Ground (regulated!) - and Rail Splitter Circuits!
Feb 13, 2016 at 5:58 PM Post #121 of 125
Hello, I lift the old topic. I would prefer to assemble this Rail Splitter because ""rock solid" virtual ground". However, there is a little offset of zero potential, -17.8 vs 18.2.  Unfortunately under load(300-500ma) i have a no little  skewness of voltage, like -17.3 vs 18.7. Vin 36v, r1-r2 6.8k or perfect 8 - no matter.  What can be wrong? I have attached a diagram, but the error did not find it ...
http://imgur.com/EeqOYR1
Feb 13, 2016 at 5:59 PM Post #122 of 125
Feb 14, 2016 at 6:52 AM Post #123 of 125
You can trim the voltage up or down by introducing a trimpot in either R1 or R2 (of course reducing the value of the appropriate resistor accordingly).
This circuit does work but nowhere near as elegantly as Wakibaki's contribution to this old thread. His circuit is cleaner and rather better sonically.
Mar 22, 2017 at 2:53 AM Post #124 of 125
Please take a look to
http://www.diyaudio.com/forums/headphone-systems/304015-better-railsplitter-virtual-ground.html
Two options about railspiltter
What are the better way?
Mar 22, 2017 at 12:50 PM Post #125 of 125
Double check you've got the LM336 the right way around.
I've built the full version with the 1085 - held the rails very tightly with less than 1/10th of a volt difference IIRC - seemed to work well but since I've either used a TLE2426 with op amp ground buffer or DCP DC-DC POL (dual output) w/ LM317/337 regs.
