Hi all,
I'm a proud and happy owner of a brand new Violectric V281. I've been enjoying it for a week now and during that time I've been reading this long but entertaining post. I have a couple of questions but first I would like to share my first impressions. (nothing new than anyone had already said really, but anyway). All my listening so far has been done with an HD800 with balanced output.
I pretty much agree with the comments in regards to the sound signature. It has a very pleasant smooth warm sound with the perfect amount of detail, a big enough space presentation (in particular with balanced output) and a breathtaking
almost scary black background. Someone said the sound is cavernuos (don't remember exactly who did though), and if I've interpreted that correctly I tend to agree, in the sense that reveals the space in which a recording was made, specially when comes to classical music. You can feel the venue, there is an amazing three dimensionality to the sound. Is like you can hear the space
in between the instruments and
around them. One recording that comes to mind to explain what I'm saying is "Barber: Adagio For Strings, by Leonard Bernstein and Los Angeles Philharmonic Orchestra. DG". The combination of the HD800 and the V281 is simply magnificent.
Now there is a couple of things I would like to ask.
- First, is it me, or the V281 needs quite some time, lets say 30/45 min to perform at it best? From cold, the bass is not as detailed and controlled as when the amp has warmed up a bit. And the overall sound is Ok but not as spectacular, or is just me adapting to the sound?
- I've found the Balanced output is exponentially better than the single ended ones. I've tried the single ended with a LCD2 fazor and I was not as impressed. (Haven't yet with the HD800) So that brings me to ask what balanced cable would you recommend for the LCD2? I live in Australia so there's not to many options locally (and quite expensive as usual) and ordering online can even be more expensive after conversion rate and shipping cost!
- One thing that excited me a lot of the V281 was the fact it has both balanced and RCA inputs which means for the first time I was going to be able to listen to my Clearaudio Concept Turntable and Luxman E-200 Phonostage with Headphones (My SPL Phonitor does not have RCA inputs as you may know). But although I like what I've heard it was not as good than when going full balanced from my NAD M51 Dac. So when using the RCA inputs in the back the Headphone balanced output becomes single ended? (technically I have no idea if that makes sense...) Or is "semi balanced"?
- My final question is in regards of the pre-gain jumpers on the back. At the moment I've set them to the default 0.0 gain which translate when using the HD800 (fully balanced through the M51 that has a 4.75V output) to a pleasant volume between 8-9 o'clock. But every single step of the volume nob has a massive increase or decrease in volume impact; for instance going from 8:30 to 8:45 is quite a big jump and I've found difficult to achieve the right volume. That was never an issue with my Phonitor, that doesn't have a stepped nob and it seems I've got used to it. So if I set the jumpers, lets say to -6 or -12 would that give me more "room" in between steps to get the right volume?
Finally, a shot of the V281 taken the spot where the Phonitor used to be...I've thought at one point to sell the Phonitor but I couldn't! I'm too attached.
it is an amazing amp, just different flavour, so I've decided to keep it and "promoted" it to my bedroom...
