zhgutov
- Dec 17, 2014
Can you tell which headphones sound noticeably better in your case, and which just barely so?Yes but some headphones sound noticeably better while some just barely so.
Audeze LCD3, LCD2C, Focal Utopia, Elear were clearly better. Sennheiser HD600/650 not a significant but still appreciable difference. Mr. Speakers Aeon Open Flow not so much but it is a 13 ohm headphone. Fostex TH-X00Ebony only has a SE cable so no choice there. I think any headphone that is laid back sounding in general may mask some of the benefits of balanced drive. In terms of a balanced drive benefit, clearly more dynamic with an increase in detail/perceived resolution, better focused imaging.Can you tell which headphones sound noticeably better in your case, and which just barely so?
Sweet my friend.I have always used power conditioners. I don't think I have had audio equipment plugged straight into walls since the early 2000's.
I currently use a Belkin Pure AV. The thing is a beast. The bottom component on this rack. Old pic. I have Yggy now.
Power conditioners are vital to home Theater. This one is nice that you can set modes. So I have a HP mode that only leaves HP
Equipment powered and cuts the power to everything else.
When using home Theater mode it cuts power to all HP equipment.
I also have a gaming mode and music speakers mode.
Will give it a try thanks.You should consider re-terminating the TH-X00 with an XLR plug. Makes a massive difference!
...Unfortunately I'm not liking the HE1000 paired with the V281; there's just for me too warm and dark a sound. So I've ordered silver headphone cables and am hoping the upper mids improve, and if they don't I may sell the HE1000...
...Lastly, I'm using a Yggy....
I wonder if the Yggy isn’t a contributor to the warmth you hear from the V281/HEK combo? I suspect my 9038-based Sonica DAC isn’t the best for my Utopias, but may be helping with the HEKs and Ether Flows.
...I might actually replace the HEK with the Utopia if the Silver Dragon cable doesn't lighten things up enough for me.
For the HE1000 have you tried changing the V281 gain settings to +5 or +10? You may find that the sound is brighter. I did.Some impressions on headphone and amp combos, mostly confirming what others have said -- I recently switched out a Bryston BHA1 for the V281. The BHA1 had excellent synergy with the HE1000, a slightly bright/analytical amp and warm cans. Now I'm connecting the V281 mostly to the HD800, where bright/warm characteristics are reversed compared to the BHA1 and HE1000. I'm loving this combo and the HD800 is like totally different headphone.
Unfortunately I'm not liking the HE1000 paired with the V281; there's just for me too warm and dark a sound. So I've ordered silver headphone cables and am hoping the upper mids improve, and if they don't I may sell the HE1000. With the V281 the only genre where I'm finding the HE1000 to best the HD800 is hip hop and maybe R&B. For everything else I listen to, classical, world, indie, I'm liking the HD800 much more.
Lastly, I'm using a Yggy. I really do not like the sound of the V281 single-ended (I would stick with the BHA1 if I only had single-ended cables). With balanced cables, the V281 provides a soundstage and imaging unlike any other amp I've heard.
Mine is Not 281 but 280 and i have same results. On 0 gain in comparison to -5 i feel more impact, nore dynamism, air and overall slightly more vivid sound.For the HE1000 have you tried changing the V281 gain settings to +5 or +10? You may find that the sound is brighter. I did.
