3083joe
- Apr 25, 2014
Yes on the v281.Curious, do you have the inputs set to RCA?
But you have a sound with the headphones from the 3.5 in that case?Yes. Just nothing with mojo from the 3.5
You can’t set the output it, auto selects (no selector)But you have a sound with the headphones from the 3.5 in that case?
If so, how do you set the output level on your Mojo when it is connected to V281?
This is why I was told it doesn’t work as a source (dac only)You can’t set the output it, auto selects (no selector)
And coming out of the 3.5 does nothing except when headphones are attached to it.
Rob Watts does not think so. He tells it does not matter is it used as a headphone output or as a line level output. You can google that with ease.This is why I was told it doesn’t work as a source (dac only)
Actually tried that setup before so I'm confused to see what seems to be the issue with how you're setting it up. I used an AQ cinnamon 3.5mm to RCA cable before and that seems to work fine, had to put the mojo in Line Level (where you hold both buttons while turning it on) and then pressing the volume down with 4 (or 3) clicks to get to 1.9V. You'll have to check over at the mojo thread as I've not had the mojo for a while.
I haven’t tried line level will do this and let you all know. ThanksRob Watts does not think so. He tells it does not matter is it used as a headphone output or as a line level output. You can google that with ease.
According to manual you can set the line level output with the following:
To set the output level to 3V ( line level ) for connection to a preamplifier press both volume buttons together when switching on the unit. Both volume balls will illuminate light blue. This mode is not remembered so when you switch off it will reset back to the previous volume stored for safety reasons.
Have you tried this (don't use the headphones with the Mojo in this "mode")?
Ok. I will try this also and report back.I have used Mojo as a DAC with the V281, with the source being either a phone (Android) or a PC. There's really no tricks to that - just plug the right cables in the right holes and it works.
The line mode on Mojo is just a preset for output volume, so don't expect miracles.
If Mojo outputs sound through headphones and the V281 works fine with the RCA input, then there's only one suspect between them: you should try a different 3.5mm to RCA cable.
Edit: Also make sure that the 3.5mm plug goes all the way in. Sometimes small variances in size cause that a bit of force has to be applied.
As I know, the output level may be set higher than 3V (line level).The line mode on Mojo is just a preset for output volume, so don't expect miracles.
Hi FumblingFoo, I own the HPA280 and DAC850 (besides the PRE630 and PPA600 to connect my Rega to active speakers and HPA at the same time), and I‘m very curious how much the RS05 can contribute to even better SQ. Did you get one as you announced above?
We were discussing power conditioners earlier. I found one that I absolutely love with the V281 and my DAC. I posted my findings on it. https://www.head-fi.org/threads/keces-balanced-power-conditioner.869377/
I highly recommend using this Balanced Power Conditioner and Surge Suppressor. Hear what your V281 is really capable of. I got the 2 outlet BP-600 as it is all I need for my amp and DAC. http://keces-audio-usa.com/products
