I agree that this unit is not ideal, but it has some things that make it acceptable for trying vinyl and any half-decent turntable is better than no turntable...
This unit is belt-driven and should provide low rumble noise, although the specs don't show that. The magnetic cartridge means that it runs with low stylus pressure, which is prefered. The built-in preamp makes it very easy to use on a low budget.
Here are some of the issues... 9 lbs is not heavy enough. The platter weighs probably 2-3 lbs and does not have much inertia. Automatic operation can be good or bad, and in the cheaper unit probably bad. Semi-automatic is prefered, because it guarantees that the tonearm would lift at the end of record but doesn't have all the other mechanical "crap" which gets in the way of good sound.
A major issue with quality turntables is the quality of the bearings, both at the platter shaft and the tonearm base. In some respects I prefer the direct-drive units at the low price bracket, because the motor shaft is likely better than whatever else a manufacturer may use on a cheap belt-drive turntable. The tonearm is as bad in both cases and very basic at best. Light composite or thin gauge aluminum tonearms without precision bearings would not produce bass well and are likely to resonate in the audio band, thus altering the frequency response. Older beat up records may require a very good tonearm and cartridge to track the groove correctly and this unit is not it... Some people might say that it "plays" so it's OK, but a needle that's "jumping" in the groove can cause groove damage and you'll hear that in less treble extension and possibly less stereo separation.
Next major issue is the cartridge and the stylus (needle). At $69 it's hard to justify high quality components, so the cartridge is very basic and may even be non-replaceable, so what you see is what you're stuck with. The stylus is probably spherical with poor tracking. All I can say in its defense is that it's not a ceramic cartridge, like they used to have in the old times...
And a phono stage with 0.25% distortion is not great either, but it's likely no worse than any $29 phono stage on ebay. Probably the exact same opamp and circuit...
All in all, if you have more money then go for a better quality used turntable with a seperate phono stage.
If you just want to try with minimal risk then the above option is acceptable. It might be - for some people - all the vinyl gear they care to have!
