For what it is worth, the Soma series makes good tables for decent money, as does Denon, if you find the older model denons, ie. made in the 80's, they were, to me, a bit spendy, but well built, and you did'nt mention if you were going to use moving magnet, or moving coil cartridges, the most common are m.m., the more spendy are the m.c., and to use m.c., you need an amp, or pre-amp, with the switch to either or, I was told by a good friend, that the m.c. cart. puts out much deeper db level than the m.m., and I think that the stylus that comes with the m.c. cart. is not replacable, so you have to junk some of them when the styli wear out, and buy another cart.
There are other phono stage amps like creek, that are not to expensive, if your amp, or receiver has no phono stage.
And then there are the arm type, like pivoting vs. linear tracking, and S-shaped arms vs. straight arms, I used to have an old Technics table, it was direct drive, and I bought Audio-Technica gel leg stabilizers for the bottom factory rubber cups, as during heavy dance parties, the vibration from the dancing would skip the stylus, and I did'nt like that, CD players do it to, just get about 40-50 people in your stereo room dancing, and see what I mean. Classic Audio, a vintage, high-end dealer around New York, has lots of tables, new and used, also look up audio retailers online, and you can find lots of good dealers, like Hi-Fi Farm in Virginia. Anyway, good luck to all looking, I will try and remember more of the older Denon t.table #, and also older Yamaha tables too!, and btw, the Technics is a very good table for home, not just DJ, IMO
