Hi xrobbo,
I am not sure how the Intona would work with your HQPlayer / NAA configuration.. seems like a cool setup.. the Intona is from Germany and I believe they offer a 14 day return period.. they were very professional to work with and got it to me in China quickly and in good condition...
I can maybe save you some time in the research....
The Tir Na guys posted lots of detail photos and some ideas on how it works...
Photos can be seen at posts starting Jan. 7
http://www.tirnahifi.org/forum/viewtopic.php?f=15&t=3640&start=90
and more info...
http://www.tirnahifi.org/forum/viewtopic.php?f=15&t=3697
The Intona guy was posting details of the engineering concepts at CA, I think his comments there were much more complete than the website.. check the very beginning of the thread.. but would be good to read through the thread in its entirety.
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/which-one-buy-uptone-universal-serial-bus-industry-standard-cables-connectors-and-communications-protocols-between-computers-and-electronic-devices-regen-or-intona-universal-serial-bus-industry-standard-cables-connectors-and-communications-protocols-between-computers-and-electronic-devices-isolator-26815/
I was considering the same idea as I guess you are considering, use HQPlayer to do the oversampling and run the M7 in NOS. I think options to tailor the sound via sample filters should be a good capability to have. One thing interesting is that I asked Miska about the processor requirements and he said (from my memory) that for PCM the processor load is much less than that required for sampling to DSD.. my thinking is that you would want to upsample as PCM to the M7 due to it is not natively DSD capable (though I really do not understand this stuff too well). So any recent multi-core processor should be OK. I have already also moved my M7 to the top rack shelf so I can get at the jumpers.. the problem is that everything sounds great now so no rush for me to try that..
hey FredA!.... I also have a Master 1 preamp ... I bought some silver interconnect wire and the mini XLR connectors and sent them to Audio-GD and they assembled them into fancy ACSS wires for me.. no charge!
Thanks for the bamboo tip...I think I had some for lunch a few days ago.. but will also certainly try the cutting board idea... I am using Herbies footers now, but have never tested for effect...
I have had various DAC's the past few years (The Audio-GD NOS1704 was really nice.. I should have tried that with oversampling...xrobbo may want to check if possible to find a used one..).. and at least 5 different DDC's, also a Regen and iUSBPower v1... The Intona SQ jump was really a shocker compared to upgrading/sidegrading between these various devices.... so much so that I will delay my planned speaker upgrade and instead take the grand-kids to Disneyland this year
I agree with everything you stated about the M7 sound.. one thing that sticks out is that you do not really need to go through your music files looking for audiophile quality music to play... almost everything is enjoyable... I listen mostly to prog rock, 70's rock, some recent pop... a little classical on occasion .
This my my current system as a point of reference:
Gigabyte GA-Z87M-D3H, I5-4670t, NOFAN CR-95c, 2x4 GB Corsair, TeraDak 210 ATX LPS, PPA V2 USB card (battery power), 32GB OS SSD (battery power), PS/2 mouse, USB keyboard, on-board
video (monitor is powered off during play), 256GB SSD/LPS for primary music (all WAV files), SSD's use PPA red thin SATA cables and suspension blocks, WIN2012 / AO , JPlay6, Mini, Total Commander. Ultrastream/Hibernate, PPA dual USB
cable, Intona standard USB isolator, PPA Regen-size USB cable, Tanly DDC, HDMI (Wireworld Starlight 5.2, 0.3M) i2S to Audio-GD M7.
Interesting setup. As for acss and xlr cables, I assembled mine using Litz copper from plussound cable. I have tried many other wires and even have a double helix acss cable. But I do prefer my plussound cAble. Another tip, not everyone would agree but I find the m7 a little more accurate with pll off.
I don't know how Kingwa did it, but his dac is both forgiving and accurate, which is not the case with all high-end dac. I love old jazz record with it. Will never sell this dac.
My chain is: Mac mini late 2012 ssd 256 8gb-> jitterbug->schiit wyrd->ab-system mkII usb cable->breeze audio du-u8 deluxe->rj45->master-7->plussound acss->master-1->plussound xlr->connex cxd-250hp homemade power amp->acoustic zen satori shutgun->Gallo 3.1 speakers
How good is the he-350?
Thank for sharing.
The rest of the stereo... this is in a small dedicated 1 listening position treated room.
M7 via silver ACSS to Audio GD M1 preamp XLR to Audio GD M3 power amp to M&D Ruby main speakers.
Master 1 also to MiniDSP/LPS (45 hz LP) to 2 Pioneer powered subs and other MiniDSP (7ms delay) to Classic 8.0B amp/w-passive pre to rear-fire tweeters (M&D Omni Harmonizers turned on side).
Sources use Audio-GD HE-350 power regenerator, each amp uses a Yulong P18 Power Purifier Filter. Cables are entry level audiophile style.
Cheers!
