juan1894
- Aug 29, 2012
I decided I'm returning my M50s because even after a little bit of stretching the clamp is just unbearable, the mids aren't even that bad on the M50s although they are very obviously recessed. I was actually looking to buy the 7506 set before I ended up buying M50s, but I don't know why but they are nigh impossible to find (canada.) I will absolutely consider downgrading if I can find them for a good price. Only reason I went up to 150+ is because usually below 150 everything is ****.
I'll recommend the V-moda M80 for that genres, but if comfort is a problem i don't think that these meet the requeriments. I have a HD558 (open backed) with a FiiO E11 and for me sounds good with trance despite its rolled-off bass (however the trance don't go THAT low in the bass region). Oh.. and it's a very comfortable pair of headphones.
