Going Off The Deep End (Or Building a Janky DIY cable):
So at around the 5 week mark, as I mentioned in my last review post. I began to believe that the cable might be holding this headphone back. I reached out to AntiCable to build me a custom headphone cable, and received no response. Well... a few months prior I had randomly come across Tempo Electric and purchased pure silver 12 gauge wire to act as jumpers on my 19 year old speakers. I went this route because the cost was the same as buying silver plated OCC jumpers and there was potentially some great physics theory behind this (I did graduate studies in physics and actually remember running a calculation where we learned that almost all of the current flow happens on the surface of the conductor. This happens because the electrons want to be separated from each other - like charges repel.) So I connected these solid silver jumpers to my dual binding posts and What!! it was like I turned up the tweeter volume on the first speaker. Did it for the second, and for the first time in 19 years I was blown away by how much clearer my highs were coming across.
So... sitting around pondering the stock cable of the Verum One, having been rejected by AntiCable, I reached out to Joseph at Tempo and told him I was thinking of doing something bizarre. Initially I was going to go for 20ga silver wire, but he suggested 24ga silver wire instead because he felt it would be more flexible. Well I went with the 24ga 4N silver wire with a loose fitting Teflon jacket. I searched online and found a 6.3mm rhodium plated plug from Eidolic. I chose rhodium since I knew I would be plugging and unplugging often and I also couldn't find a 6.3mm silver plated plug. I also found some 3.5mm rhodium plated plugs on AliExpress (because I couldn't find any reasonably priced alternatives elsewhere). And I chose rhodium for the 3.5mm since I knew that I would be disconnecting my cable from the Verum One after each use and rhodium has high durability and better than nickel conductivity (but less than gold - pros and cons). I bought some 8% silver solder and pulled out my old soldering iron. This was probably the first time I had used the soldering iron in at least a decade.
Let me be clear, up until this point I hated anything DIY in audiophile. I figured, how the heck can DIY outperform anything that has been well engineered. Well, maybe more on that later, maybe not. We are now entering the "cable debate" and I fully expect that everything that follows will be read with great skepticism. Yep. Totally get it, and I lived in that world for 19 years since I became an audiophile. My friends out in STL owned a hifi shop and after store hours we would do listening. And I've sat through A/B of cables upwards of $40k just for interconnects and I was never blown away. As a former hifi salesperson, I've demoed and been demoed silver plated OCC wire, and pretty much don't like how that sounds, period. So no hard feelings from me if you believe that cables don't matter that much, I get it, and frankly had I not heard the difference on the Verum One, I might not have believed it either. So the debate is the debate and I have no intention of resolving that cable debate. The real purpose, of trying DIY out (for the first time ever) and for having this discussion was to see if I could make an improvement on my Verum One with an all in $65 investment. I figured that I already loved them and would buy them again, could I make them even better like what happened on my 19 year old speakers. Moving forward I will refer to the general theorcore wires for optimal sound quality as just "solid core."
Immediate Listening Impression:
Yes. The answer is yes. There was a difference. Admittedly not a massive difference, but there was a clearly audible and significant difference. And it changed the way I looked at the Verum One headphone. One of the first albums I wanted to hear up front was my original mastering CD of Star Wars. I had listened to this same album about a week prior pre solid core. When I put it on, I started to cry when I got to Leia's theme. Something was uniquely different and much better than before. What was going on? The instruments actually sounded... different, better, more tonally accurate with better timbre. I was hearing more detail in the orchestra. Many regard this original recording to be inferior to the remaster of the 90s (which I also own). But using the solid core headphone cable from the Schiit Hel to the Verum One. It sounded lots better in all ways. There was zero downside. And then I started noticing that the bass was both a little bit tighter and fuller sounding. Very very weird for a person who fundamentally didn't believe in DIY and silver wire. Put on another album to see if I was imagining things and I heard the exact same sonic effects:
- slightly tighter and punchier bass
- more tonally correct mid-bass and mids
- gentler yet more detailed highs
After an hour and on into the next 2 weeks:
I decided to let this burn in for a couple of hours but noticed that after an hour things had already gotten better. So I started rolling albums. This cable replacement for sure made the Verum One sound better on every genre. Classical became even more enjoyable as the solid core cable seems to remove top end sibilance yet provide more detail. Instruments sounded more and more real. Jazz music was incredible. It was already excellent on the Verum One, but oh yeah baby... So I started putting on some of the more difficult genres. I decided to give everything a real run for the money. Run the Jewels 3. Where this album had some top end harshness on the stock cable, now that was mostly gone, and bass was tighter and more impactful. Vocals had a sort of "correction" to them that sounded more real to me rather than sounding a bit processed.
The next album to really open my eyes was an album of Franck organ works. Okay, let me restate something from the first review. The Verum One is a
full range headphone. BUT... how full range depends on everything upstream. With the solid core cable, holy cow, the organ was sounding sublime. I was hearing the beginning and end of the organ. At one point I kept thinking someone was hitting the floor or the table I was working at, and I kept looking around to find the cause. After about 10 minutes of being disturbed by this odd sound, I finally realized it was the Verum One. I was hearing the footwork!! Oh my. Bass was dramatically improved over solid core. And this is every album I played. Same thing over and over again.
One of my all time favorite popular albums is Sting's Soul Cages. I had to hear this. When I played it, yes all the same things held true. But more importantly I was hearing things in the album that I had not previously heard before. And this is an album I have played hundreds of times over on multiple hifi systems. It isn't the best recorded album, but I treat it as a reference because I just love the music. So for me to hear things on this album I've never heard before, instruments in the background that I didn't even know about? Well thank you Verum One headphone.
As the next 2 weeks went on, I was blown away by album after album. Classical was even better. Jazz was exquisite. Much more of my popular rock etc music sounded better. And last but certainly not least, electronic music was elevated. Perhaps one of the more annoying aspects of electronic music is the top end. And frankly, this is one of the major reasons I don't like most headphones, because the top end is usually a bit high and that exaggerates a lot of the ear piercing aspects of electronica. As I mentioned the Verum One already has an excellently smooth top end response. But solid core via the Verum One, really cut back that top end glare even more, adding a gentleness and higher degree of clarity than with the stock cable. It was near unbelievable. How could a shoddily assembled DIY be doing this? It made no sense.
Going solid core creates more "problems":
Wrestling with my disbelief on what I was hearing and getting blown away by nearly every album was starting to make me thing of doing something else. I wondered... what if I made myself a cheap $25 24ga solid core silver RCA for my main system? There's no way that it would sound better than my $400 Chord interconnects. No way... So I made it on a whim, and yeah... I heard soundstage for the first time ever on my speakers. So this then leads to the next upgrade. I was already using a multibit Panasonic portable CD player from 1991 with line out for my headphone setup. And it was a 1V 3.5mm out going into the Hel 3.5mm input. So I made myself a solid core 3.5mm to 3.5mm interconnect.
Okay, the solid core headphone cable to the Verum One was an audible but not massive upgrade. But good enough to get me going on this journey. Swapping in the solid core 3.5mm to 3.5mm, however, was indeed a massive upgrade on the Verum One. And doing some A/B with the stock cable I was able to convince myself that the solid core 3.5mm to 3.5mm was actually more important than the solid core headphone cable.
Full Solid Core:
So now I'm what I'd consider fully solid core. All the signal wire that was stranded was now replaced with solid 24ga silver wire in a loose (air gapped) Teflon jacket. I was impressed with the Verum One before, but on full solid core, the Verum One began showing it's true potential. This is a very very good headphone. And frankly, the guy making it is selling it for too little money. But in a way, the price is appropriate since he isn't a massive company. So let me say this, if this headphone were to be made by Audeze or Dan Clark, I don't see how it could be sold for $350. But that's the headphone selling business, and I'm not in that, so let me not say anymore on that topic.
Below are some of the impressions I have with a fully solid core setup driving the Verum One:
- The sound has to be some of the most accurate tonally and timbrelly I've ever heard short of some very expensive speakers. Having been to hundreds of symphony concerts, maybe a hundred jazz performances, I feel very comfortable saying this.
- The top end has incredible detail and nuance which can often shock you as you will hear details at a level you've never heard before.
- And probably most importantly, the bass suddenly arrived. Electronic music was very enjoyable. So clearly the cheap 3.5mm to 3.5mm I was using was cheap garbage compared to the $15 DIY cable I had assembled.
On one recording of a quartet, I kept hearing weird sounds that I had never before heard. I listened closely and realized that I was hearing the occasional foot stomp of one of the players, the occasional out breath of another, and I could hear slight paper movement. It was a real head shaker. This level of awakening was album after album after album. I hear effectively zero sibilance at this stage. Playing through my electronica collection at random was joy after joy now. I now had the bass I was looking for.
And this is where I have to claim that this headphone turns crap into gold. I wanted to push the limits, so I began grabbing some of my most offensive recordings. Recordings that are either very poorly done and/or that have annoying things happening elsewhere in the mix. Example, I dropped some Aphex Twin Ventolin EP, which I love, but must admit has a number of "ear murder" tracks. Wow, wow, wow. Crap turned to gold. I put on a janky jazz album from Duke Ellington, and it suddenly sounded amazing. I put on some NIN and Soundgarden (more ear murder) and there was no ear murdering happening. What the heck?? I can't even think of an album that sounded poorly on this solid core backed Verum One.
Verum One scale hard:
I haven't done this kind of scaling exercise with other headphones, but the Verum One headphone have the capacity to pass through an absurd amount of detail. All of my niggles with this headphone, ranging from wanting more bass and a slightly annoying cable, were now gone. This is a headphone that can and will rise to the occasion. It is a headphone that responds to nuance across the frequency spectrum, playing every sound from the faintest to the minute. It is a audiophile headphone on a budget. It is a headphone that you can "upgrade" by focusing on the upstream gear. The better the upstream, the better this headphone sounds. To date, no distortion.
In the pre solid core days I had actually ordered myself a Schiit Vali 2+ because I wanted to spice things up on the Verum One. After solid coring everything upstream from the Verum One, I canceled my Vali 2+ backorder and started looking at a headphone amp that could really drive at 8ohms. I just wanted to see if there was more for this headphone to give. Answer: yes, there is actually even more that this headphone can do. Like I keep saying, this headphone scales, and it sca
