luberconn
- Jan 27, 2014
That velocity looks great!
I keep waiting for the top to pop open at the split and it start singing Uncle screw*r from South Park.
It does sort of look like Terrance.
I was going to say be careful if you use it on a mech since there are quite a few reports of them shorting out in the FastTech discussions.
Seems some of them have bad insulators yours might not apply though.
lol, it does kinda look like terrnace and phillip! yeh, i had some slight problems with mine this weekend. i watched a review on the clone and the one i saw said it was adjustable contact. it's NOT. i loosened mine a little, just goofing around with it, and put it back on. not even thinking about it. later i noticed the ohms fluctuating on my istick 50w. and a few times my istick stopped working. wouldnt fire and screen off. i plugged charger and it came back on. i still noticed my ohm reader fluctuating between .5 - 1.5 ohms. i get home and screw the center pin back tight and now it reads a solid .5ohm and had zero problems since. i wonder if that is the problem others have experienced. 510 IS NOT ADJUSTABLE!!!!!!
the only thing i dont really like about it is the top spinner part is sorta loose, as in easy to turn. i thought it would have a little bit more resistance. it really isn't a problem. when i'm not using it, i just tighten it down all the way to close off all holes. but from a build standpoint, i think the tolerance could be a little tighter on the top spinning piece. but then again, i paid like $24. imo well worth it. i'm really loving this atty.
