PatOMalley
- Jan 8, 2009
lay the cap on table so you can read the label. Signal enters from elft out on right. Bare wire is what I do, air being the best dielectric. do not heatshrink anything, bad dielectric. Use teflon tubing if need be.
In cases like my metal covered Obbligatos I will use a small but of electric trape along area of the cap where the lead might touch. Blu Tac in that area works for me, too.
Originally Posted by MikeW /img/forum/go_quote.gif I ordered my 4.7 uf sonicaps a few days ago, should be getting them any day now. What the best way to install them? as far as soldering them, I know you said to desolder the old caps and suck all the crap solder off, that sounds simple enough, should I use some kind of heatshrink tube to insulate the leads? or can I just use carefully routed "bare" leads, does it matter which lead go's to what side, polarity? If I don't have enough "lead" on the cap I can just solder some teflon insulated copper/silver wire to the lead and heatshrink it? got 250+ hrs now, sounds good this dac is alot mroe detailed and resolving then the older version, im sure because of power supply. I do have some sibilance and the high's are a bit to sparkly, there is alot of warmth and bass but the lowest lows are simply not there, this happend on the older version too, I guess it's a limitation of the older dac chips, maybe replacing these output caps will help get some more bottom end. Thanks Mike |
