SpiderNhan
Off to test the VERZA with my M-100 and V-80. Be back with impressions later.
Conversely one of The Amazon reviews on VAMP said he sent it back to Amazon because he couldn't get the volume to go low enough to not hurt his ears.
I think the two AMP differently but definitely not a 30% difference, and mine has some hissing issue plus in need of the firmware update. I will test it again once my VAMP is back from RMA (again). I do suggest to have your VAMP RMA back to V-MODA for a check up.
If a reviewer said they that, their credibility is lost with me. There is no such thing as an amp that can't be turned low enough. However, this being Head-fi, I am bracing myself for a post from someone contradicting that statement.
Does anyone with a verza have an ipad mini? I've been considering one but saw a few threads on the headphone out being kind of weak.
I don't believe so. Remember the iPhone 5 has the HP port on the bottom. TBH though, I have not seen a picture of the bottom of the iPhone 5 Metallo case. Given that the GS3 case has an opening for the HP port though, you can safely assume that the same exists for iPhone 5.
Anyone else bothered the hoops you have to jump through to get the bass boost activated? I wish they switched that with the 3d button. I would probably never use that one anyways.
Look at this pic - it is clearly covered.
Edit- actually the right end looks rounded. Maybe its the pic because the port seems like its farther to the edge when its naked.
For anyone who has a smartphone or player that doesn't anticipate a matching Metallo, I am using 3M duo-stick strips with my Iphone 4 and Verza. It hold securely and is removable.
