Using an old Yamaha RX-E100 as a receiver for headphones.
Jul 31, 2013 at 10:41 AM Thread Starter Post #1 of 6
Wiener4Hire
SO i am just getting into the whole thing about headhphones, and i'm currently looking at at the HD 650 from sennheiser. I want to use them with my PC, and i looked around and quickly figured out that i will ne an amp to use them properly. Currently i have my PC 360 headset plugged into an ASUS D2X soundcard, however i also have a couple of old Yamaha NX-E100 speakers lugged to an RX-E100 receiver (with and attached CDX-E100 cd-player if that matters.) Now my question is, would this receiver be good enough to run these headphones with 300 ohms of impedance?
Jul 31, 2013 at 2:30 PM Post #4 of 6
I would make a guess that the Yamaha RX-E100 headphone jack could drive 300-Ohm headphones.
I would say to run an analog audio cable from the Asus D2X's 3.5mm (green) jack to the RCA input (red/white) on the back of the RX-E100.
If you ended up needing an external headphone amplifier.
PAV2V (Pocket Amplifier 2 version 2), sells on eBay for around $60-$65
Schiit Magni, $99
Jul 31, 2013 at 2:40 PM Post #5 of 6
Onderful, i already have the receiver hooked up to the D2X like that so i can use my speakers for the pc as well as for playing CD's. As a followup question, would it be worth it to get an optical to RCA adapter for the optical output  on the D2X that goes into the receiver?
Jul 31, 2013 at 2:56 PM Post #6 of 6
An optical to RCA adapter, sound like your describing an external DAC (Digital to Analog Converter)
Asus Xonar D2X comes with a good DAC chip, I would think you would want to spend $150-$200 to make it worth buying an external optical input DAC.
