kontai69
- Feb 27, 2005
I have come up with an elegant way to minimize the chaffing of the cords by the edges of the square notches present in the earcup holders of newer Grado RS-1/MS-Pro headphones (PS-1 also?). This issue was brought up in this past thread...
http://www6.head-fi.org/forums/showt...ght=rs-1+notch
I used a black foam sheet with an adhesive backing which I found in the arts and crafts section at the local Wal-Mart. It is around 8x12 inches in size, around 2mm thick, and costs around $2. They come in many colors, including bright pink, but I thought that black would best match my MS-Pros.
I used a disposable razor blade to cut out a small rectangular piece of foam with the same dimensions of the notch, removed the adhesive backing, and then fitted the piece into the notch. Temporarily sticking the cut piece of foam on the end of a toothpick makes it easier to position it into place. Repeat for other side.
Here is a pic of my treated MS-Pros...
The foam is fairly dense and shouldn't compress over time. Also, the adhesive is pretty strong so I think it should stay in place for a while. If it should happen to fall off in the future, I have enough leftover foam to make a thousand more pieces.
For you car audio buffs, these foam sheets make an excellent gasket for mounting door speakers.
