kazsud
Would like to see picture of your entire digital chain if possible.
You'd need a full frame camera w/ a ultra wide lens.
Does the Startech require 24V no matter what, or can it run with a lower voltage?
All PRO SERIES models have an additional internal discrete module called APF™ (Advanced Power Filtering) which filters out digital and dimmer hash as well as any high frequency noise that is above the audio range. Some off-the-shelf add-on modules saturate and lose their filtering effectiveness as the load increases, but by using a high power discrete design we were able to create a filter that stays effective over the full operating range.
By using both Common Mode and Differential Mode topologies in series for the filter design we are able to block virtually all of the unwanted noise that is between the AC line and ground, and also the two sides of the AC line. This has the additional benefit of reducing ground loop problems in your system. High frequency noise currents in particular are highly attenuated in both directions so that any line noise that could be generated by one of your components is not allowed to get back into your main A.C. wiring so if you use a number of PRO SERIES Power Conditioners in your setup, you can distribute and isolate the noisy components from the sensitive components in your system. Additionally, any signals above 10kHz are filtered from the line with over 40dB of attenuation above 100kHz and beyond.
The idea of this thread is to kind of consolidate all the info in my other XU208 and AOIP threads - and pickup on the Singxer F-1 XU208 discussion. I can't count how many people have PM'd me to open a new F-1 thread.
So to not only discuss this Ultra USB chain, but to resume that discussion.
I would consider trying a DIYinHK Pro3z in place of the F-1, if anyone wanted to send one to me for a go.
http://www.diyinhk.com/shop/audio-kits/111-xmos-192khz-high-quality-usb-to-spdif-with-ultralow-noise-1uv-regulator-wmanual-power-switch.html
I never bought a SU-1, as I wanted control over the power supply. And it was more expensive. My experience with toroidal vs R- core LPS's showed me R- Cores superior.if possible would be good to know how you like SU-1 as well.
Yeah right :rolleyes:Buy the new Naim Core, attach your drive(s), add your DAC of choice via SP/dif and call it a (very good) day.
Expected response. Linear PS including what runs the USB ports and drive options, purpose built codecs, FW and control app. Proper single galvanised 75 ohm BNC output. Instead of fixing PC problems, try not having them for a change.:wink_face:
Have you heard a Pardo supply? I LOL'd and felt sad for those that bought at the same time. Not quite up to speed if you get my drift.
I'm out as this is a computer audio forum and while the Core will interface via file share and store it's probably stretching the intent here. I always felt this forum useful for those on a budget and trying to get the most for the least. Once you get to kilodollars(besides the PC) and Rube Goldberg rigs, I personally believe other options become more viable.
Enjoy your journey. It hasn't ended and experimentation is fun. Try not to be so angry.
Expected response. Linear PS including what runs the USB ports and drive options, purpose built codecs, FW and control app. Proper single galvanised 75 ohm BNC output. Instead of fixing PC problems, try not having them for a change.![]()
