The project isn't dead yet
- The case above was really a bit too thin. I'll revert to the more conventionnal Hammond 1455C1201. Let's be a bit practical for once.
- Isolation is nice and all that stuff but I decided to keep it more simple. After all, it is made to be used with headphones so there's no risk of groundloop. I'll buy a Doodlebug for a home setup if I feel the need.
- The njm4556 in an opa134 loop is definitely a bit marginal. I'll go for the faster lm6171 (vfb) or lme49713 (cfb) as buffer. Those can push just as much current. The lme49713 has the edge for stability in sims.
- I also decided to go for a more modular approach. One board for the dac, one board for the amp. If I mess with one section, I won't waste all the pcb
Both boards are 50*50mm, with 3.5mm clearance on each side (to fit in the hammond enclosure)
- I found a more compact DC-DC converter, the Murata MTU2. It gives me +/-12V. I'll filter the lines heavily but, thanks to the good psrr of the opamps at audio frequencies (and especially LF), I don't feel the need to regulate the supply.
So where am I (after some help received on Diyaudio from jcx and Avro Arrow)...
Headphones amp section:
DAC section:
There might some last small changes on the pcb but now I'm almost ready to send the files to oshpark.
