boead
- Nov 15, 2003
My dilemma is that my PC is about 25 feet from the stereo. I can either run a long RCA cables (which I already made with Belden wire that sound ok) OR I have to run long digital connections. Either Optical or Coaxial RCA.
I’m not even sure is you can get or make a 25-30 foot coaxial cable or optical TOSLINK.
Is there an inherent limit to how long a digital wire can be? I mean a point which degraded sound quality becomes significant?
I found that the longest a USB cable is sold is about 16 feet. Why? Can a USB cable for an audio device be longer then 16 feet?
Is it best to use an external DAC for a Computer close to the computer and use a long RCA to the preamp
OR
Is it best to use a long digital cable from the computer to the DAC at the rack with short IC’s to the preamp?
OR
