milamberXM3
I'm eager to know this too, @milamberXM3
Sorry, looked at the wrong device. Mine is also locked to 16/48.
...and I tried Windows versions from Windows 2005 Tablet PC Edition untill Windows 10.Sorry, looked at the wrong device. Mine is also locked to 16/48.
Reiyin Global Store said:Hi, this product supports 16 bit 48 kHz, doesn't support 24 bit 48 kHz.
I just noted this item some days before.FYI: I got the Avantree DG60 yesterday. My initial impression is (edit: compared to the Reiyin); quicker connection, much better range and I also think the sound is noticable better. More open and detailed sound, with punchier bass as well. Still 16bit/48khz though, I'm afraid.
https://avantree.com/dg60-bluetooth-usb-audio-transmitter
Digital input:I found an interesting device on Ali that could potentially match all needs.
New version ES9038 Decoder Xmos CSR8675 Bluetooth 5.0 APTX HD LDAC With case For hifi amplifier audio T1047
USB XMOS version, USB ARM + CPLD version, No USB version
ES9038Q2M | Nichicon | APD191 | transmit power
transmit decoding chip | transmit tooth capacity | transmit low noise LDO | isolated power module
Monitoring tooth 5.0 HD pass-through BU38 is equipped with CSR8675 Bluetooth chip,
supporting LDAC / aptxX HD / aptX / AAC / SBC and other audio encoding,
high-quality digital audio is connected to ES9038Q2M through Bluetooth 5.0 CSR8675 and output,
achieving 96Khz / 24Bit decoding far more than CD sound quality.
100Mhz Low Phase Noise Vibration
ES9038Q2M chip is particularly sensitive to clock phase noise, low phase noise clock signal
Very important for audio signal restoration
Operational amplifier dual-voltage power supply Operational amplifier 7 of BU38 uses standard dual 15 volt voltage power supply to eliminate the negative impact of the use of direct, insulation under the power supply sacrifice on the sound of the two original sources, he sound is transparent and natural, not harsh, three balanced, and the use of only Ling op amp seat, convenient for players to change the op amp of different sound styles
I contacted the seller but didn't get any response yet.
I don't know if this is a transmitter.
I have no glue how the connection between the USB-DAC and BT is made.
I'd like to know if additional USB power is needed when connected by USB.
I'd like to know how the output type can be switched.
Any opinions?
(OCR and translation without warranty)
Haha Think that reference might be lost on 99% head-fi'ers but I am sure Couple of us will know ;]This is an awesome thread!
love the name Milamber. Or should i call you Pug?![]()
I've purchased Sony WH-1000XM3 headphones, and they sound great with my Android Phone (connected via Bluetooth with LDAC). On PC, I am using Creative W2 Bluetooth dongle, which supports only aptX, and the sound is a little bit dull.
What would be the best solution (ideally below US$ 200, but US$ 300 is acceptable) for USB DAC to Bluetooth w/ LDAC for PC dongle / card? Or, optical / Toslink to Bluetooth w/ LDAC?
I have found Toslink to Bluetooth w/ aptX HD adapter, but none with LDAC support.
Topping D50s
Costs you 250$
You can always order it from Amazon and ship it back for free if you don't like it.
Some reviews if you don't know about it already
https://www.audiosciencereview.com/...nd-measurements-of-new-topping-d50s-dac.7914/
Topping D50s does not transmit Bluetooth.
