SeeHear
- Jan 10, 2012
1. Then you're saying all your equipment is inferior to amirm's tested system of standard laptop, generic USB cable and $129 Topping D30 DAC because with that system you couldn't have found USB inferior to anything because the artefacts from USB system are well below audible, as you yourself have ALREADY agreed!
1a. Again, obviously not as good as amirm's relatively cheap system which has NO audible USB artefacts and therefore can't sound inferior.
2. If you really can hear the difference between USB cables, you've got a seriously screwed/faulty system/DAC. It's obviously performing about at least 100 times worse than amirm's test system with a generic USB cable! Ouch, I hope you spent way less than $129 for it?
2a. If you really are hearing such differences then you "have to believe they put considerable" incompetency into their USB implementation!!!
G
Uh, no. I said what I meant. Either you're trolling or simply poor at English comprehension - regardless, not my problem.
Your naive assertion that the noise floor is all that matters is proof you're don't know (or care?) what the music sounds like through your system.
A very Merry Christmas to you!!!
