jrosenth
- Nov 27, 2004
Outside of the kimber are there and specific recommendation for usb to mini usb like the kimber?
Originally Posted by audioengr /img/forum/go_quote.gif Here are some asylum threads on the same topic: Computer Audio Asylum Computer Audio Asylum Computer Audio Asylum As you can see, there is a lot of anecdotal evidence supporting the physics, and the difficulty of making anything jitter intolerant. Steve N. Empirical Audio |
Originally Posted by flecom /img/forum/go_quote.gif seriously? i mean, really, seriously??? teflon USB? |
one of the problem i have had with the really crappy USB cables that come with devices are that their conductors are TOO thin causing too much V drop across the cable (mind you these are like 1ft cables, so you can imagine lol) |
you CANNOT "color" 1's and 0's, additionally jitter is so massively over-rated, its just reaching for straws, 99% of people are not going to notice 99% of errors, so please stop with the FUD |
krisjan;4854907 said:ok, i have read some of the papers by steve, etc. and the concept of jitter influencing audio quality makes perfect sense, but in terms of the practical implications for the leymen such as myself... i'd like to hear some kind of qualitative description from someone knowledgeable in terms of how audio influenced by jitter sounds - is it a loss of detail? or weird pitch-bending effects? audible noise? Does a low-jitter system simply have more clarity...This is difficult to describe. Some folks call it "veils". My wife describes it like looking through a dirty window. After the jitter is reduced, the window is clean and you see all of the detail outside and none of the haze on the window.
Second q - Can jitter affect the latency performance of a soundcard such as the emu0202, or is this a completely different issue altogether - in other words could i gain a millisecond or two with a synergistic cable as opposed to a belkin gold, or would it only be sound quality gain...(sorry if this is a dumb q, but since jitter is a time related thing i was wondering if it could affect the latency)
Latency is completely different issue. Has to do with the software stack and hardware implementation in the computer that drives the USB interfaces.
Steve N.
Empirical Audio
Originally Posted by Edwood /img/forum/go_quote.gif The evidence is anecdotal, but not at all empirical. USB has been argued to be asynchronous and buffered, making it less than ideal for very high speed high precision bidirectional data timing. Upgraded USB cables will not make up for this fact. You are more or less putting high end Z Rated racing tires on a pick up truck. -Ed |
Originally Posted by jrosenth /img/forum/go_quote.gif Outside of the kimber are there and specific recommendation for usb to mini usb like the kimber? |
Originally Posted by audioengr /img/forum/go_quote.gif The best available currently are the Synergistic and the Locus Design Axis. These are spendy, so I would recommend the Belkin Gold for around $20 for 5m. This is what I generally use. Steve N. Empirical Audio |
Originally Posted by olblueyez /img/forum/go_quote.gif Do you think those cables are worth it or is the difference small enough for you to just use the Belkin as you say? Also, can you give is a ball park number as to how much better an expensive USB cable can sound, 5%, 20%, etc.? |
Originally Posted by myinitialsaredac /img/forum/go_quote.gif Steve, Thanks for all the info. Whats your opinion on using software resampling such as the secret rabbit resampler for foobar I think you alluded to in your white papers. |
Also, If I'm correct you are totally against using optical toslink, and believe usb to be a much better solution even with the pcm2902 usb handler chip that is employed in a lot of dacs? |
Basically what I'm am getting at is what would you recommend to get my audio out from my pc to the headroom microdac, (toslink or usb)? If you want to help out a reply here is fine, or a pm works also |
Originally Posted by audioengr /img/forum/go_quote.gif Packetized networked data is certainly a superior method to USB, but has issues such as non-support for higher sample-rates, limitations to player software choice, usually more costly and interference if it is WiFi. The cheapest way currently to get hi-res is USB. Steve N. Empirical Audio |
Originally Posted by audioengr /img/forum/go_quote.gif Go ahead and put your head in the sand. The rest of us will have better audio. |
