bombsight
- Nov 22, 2008
Okay guys, I've been trying to cope with all of the UE tips for a while. My ears are rather small (Because I'm 16), so I've resorted to using the smaller pair of tips that were included with the UE's. They work well, but I sure have to go through a lot of trouble for this. I Take a rather long time to insert both ear buds and make sure they are in well. It could be some slight OCD, but I also push into the buds every 10 minutes to make sure they are sealed as it seems like they are prone to coming out. When they come out, I an tell the bass disappears etc. Often-times they're uncomfortable after a certain amount of time and I have to take them out and reinsert them. It seems like they're also an ear wax magnet although I clean m ears daily. I've tried the foam tips, but it seems like they don't make a great seal for me by the lack of bass from that solution + apparently I need to get new ones every once and a while.
Does anyone know any good ear tips for UE-Super fi 5 pro that I can get that would:
1. Provide an excellent seal to retain the bass and other elements
2. BE COMFORTABLE!
3. Quick and easy to insert
4. Not prone to falling out with mild movement (i.e Jogging, working out)
5. Not a rip off (I.e 10 foam tips for $20) I swear 10pounds of that material costs like $1
Thanks for any responses,
zaa
2. BE COMFORTABLE!
zaa
