rb2013
Author of The 6922 Tube Review
- Apr 12, 2013
I wouldn't disagree with that. That's why I will continue to use a single cell LiFe4Po battery on my Regen with a smps power supply trickle charging it. All for less than $30 and it provides galvanic isolation on the Regen. Of course you need to modify the Regen with a simple DIY and your DAC (preferable) does not need a 5V vbus feed.
I think folks overrate the effects of smps feeding noise back into the mains and how that effects SQ.
Far better places for the LPS-1, such as my DAC/Hugo (coming soon) and the PPA USB card.
I agree on using the LPS-1 in other places - the max current it can supply does limit that though.
I can tell when using a SMPS in my system - even the iFi iPower. Sold all mine. Even the SMPS in the Mutec MC-3+ USB and AOIP REDNET 3 where detremental. Those were sold as well. I won't use anything by a LPS now.
I have not had much success with LiPo batteries - they seem to dampen or limit dynamics. Depending on which battery - they can have very high noise levels. Higher then a well designed SMPS. And their ability to supply current on demand is quite limited - judging by their slow rise times.
