- Jan 30, 2011
Are you using any EQ Chris?
Yeah, I floored everything and built it up and 1Khz absolutely must be the lowest slider. It's usually 500 for me on a 10 band EQ but 1Khz takes me from shout to superb.
Just for kicks used your AR2 settings on my X5/A5 rig and found a bit like muffled or less openness. Not a sound expert just describing the test, I used the Viper Eq as it was easier to use manipulate values. Hopefully that is what I supposed to get. I still feel a quality sound signature from this unit,
Thanks BTW I watched your video comparing planars, DD and BA. That is very helpful to understand now your settings and what you are trying to address. Pretty awesome for me. Hopefully you can share later some of your EQ settings for planars.Yeah I use a slightly different version on the AP200 so depends on personal taste and a little bit on device it seems
That AR music player pro looks like an exact ripoff of UAPP.
"A" "B" ing with the ME.1 and Audeze and they are more alike than I thought. Fan freakin tastic with a tad of user input via EQ
I've been actively contemplating acquiring one of these. Can you see any advantage with respect to sound quality of one over the other? How do they do with reproduction of various types of percussion? Some reviews, at least of the isine, have seemed to imply a relative lack of lower-end dynamics.
Without an EQ they are both very linear in bass. unnaturally so. That is an easy fix with a quick boost to 30-125hz peak at 55-70.
More on the discovery side for everyone is between 1Khz and 9Khz.
The clarity level is unrivaled by anything not planar. Even before adjusting you get amazing detail retrieval. That makes it worth it to me to figure it out.
The cable on isine is ghetto. on ME.1 it's pimp jewelry. I like the bling
Been fairly convinced about the advantages of planars and the clarity/detail is an attractive feature. It's great one can readily increase the bass quantity.without harming the rest of the spectrum. How about the transient response and impact in the bass?. Been leaning towards the ME.1 on the basis of reported comfort/ergonomics/build quality.but if there were and sound advantage with the isine20...
