castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
Jitter is consciously perceptible at fairly high levels. Any modern DAC, even little baby Chinese DACs, have a clock that are good enough to reduce jitter to levels that are not perceptible as jitter. So the battle isn't with old-school, extremely obvious jitter.
Instead of just explaining how jitter at low levels matters, let's see what respected industry manufacturers have to say:
MSB (builders of what many consider to be the finest DACs in the world):
"Our years of experience taught us amplitude (DAC) precision contributes to the realism of the instruments and voices while low clock jitter decreases ‘digital harshness’ and increases focus. Jitter simply takes the pleasure out of the music and creates listener fatigue."
Antelope Audio (famous in high end pro audio):
"Leading producers, sound engineers, artists, and movie post production studios worldwide are using the 10M Atomic Clock together with our high-end Trinity master clock. They usually describe it as “mind-blowing”, an “instantaneous improvement”, “superior”, and fundamental in bringing “more detail, ambiance, and naturalness” to the digital signal. The results are described as “wider and more solid” with “crisp transients and a 3D depth of field.”
Low-level jitter does have an impact on audio perception. This is well-known not only by manufacturers, but by DIY'ers as well.
A comparison with inter-module distortion is handy. It's known that IMD isn't generally audible in modern equipment -- because the brain filters out IMD artifacts, but IMD is seen as negative because it is theorized to lead to listener fatigue (it's a theory because it involves neuroscience but it's still a widely accepted view). You won't hear jitter, or noise in general below a certain threshold -- but that doesn't mean that it doesn't effect you.
I am certain beyond any shadow of a doubt -- if readers of this thread were to plug their headphones of choice (well, headphones that aren't trash anyway) into my reference system, the difference between it and their DAPs, little integrated units, etc, were would very obvious. A lot of that difference will come down to the effort and expense gone into reducing jitter and noise in the system.
enough with the well known non facts already. how about actual facts for change. I'm getting tired of telling you this isn't a contest where you win everything with rhetoric and self confidence alone. you call random stuff significant and audible without proof, saying it's well known every now and then as a lame trick to make any single of your opinions pass as some self proclaimed consensus.
right now someone mentioned an AES paper, an actual experience with an actual method that contradicts your so called well known "facts". and instead of considering that your claims are exaggerated, or talking about what you find arguable in the paper, like anybody following logic would do when the experience contradicts the guess, you go on as if nothing happened with some marketing crap as your side of "evidence". we don't care about what batman thinks on the matter of jitter. that's not how you demonstrate something. subjective opinions are not objective evidence.
in this sub section of the forum, make the claims you can back up, or stop making them. also you can go in other sections, where anything said is considered an opinion and as such doesn't need evidence.
