Under $250 PC solution for Senn 555
Feb 26, 2005 at 11:58 PM Thread Starter Post #1 of 9
kerecsen
Hi everyone,
I have a Senn 555 that I would like to use with a PC. I'm willing to spend at most $250 to turn it into a decent source.
Browsing through the forums it seems I have the following options:
- Getting a (Total) Bithead ($200-280)
- Getting an EMU 404 ($100) and a low-end PPA ($120)
- Getting a cheaper card (chaintech, Live 24 - $30) with a better amp ($200)
- Getting a more expensive card (EMU1212, m-audio audiophile) and a cmoy
- Getting something cheap to output coax-toslink, getting a cheap outboard DAC and a PPA
- Forgetting the whole PC thing and getting a Sony CE595 SACD player ($130) with a low-end PPA ($120)
Are there any options I haven't listed? Which do you think will result in the best system?
Thanks!
Tamas
Feb 27, 2005 at 12:13 AM Post #2 of 9
I'd go for the 0404 and a nice PIMETA or a cheap PPA. I can assure you that you will be most pleased with the result.
Feb 28, 2005 at 5:27 PM Post #4 of 9
the man has a Katamari Damacy avatar. He's obviously incredibly cool. Why would you *need* other opinions?
:p
Given that the 555s aren't extremely high-end, and the 1212 compared to the 0404 is definitely a difference you'd want high-end headphones to appreciate, his advice sounds very sensible to me. Your 'phones are mid-end so go for the mid-end card and the mid-end amp...synergy
Feb 28, 2005 at 11:40 PM Post #5 of 9
I'd have to agree with Helter Skelter. I got my 0404 last Friday. Previously I had been using both the M-Audio Revo 7.1 and the Chaintech AV-710. In both of those cases the amp was my Headsave Classic and the cans are HD-555's. Adding the 0404 blew both of those cards out of the water. I really love the sound of the 0404, and though not that experienced I think the Headsave Classic is equivalent to a higher end PIMETA or a low end PPA. I think it's an awesome budget combo that has kept a big grin on my face since it came together.
A_Sr.
Feb 28, 2005 at 11:44 PM Post #6 of 9
i would also go with the emu0404 and PPA recommendation. IMO, this combo should work well even when you decide to upgrade the headphones.
Mar 1, 2005 at 3:44 AM Post #7 of 9
seconded. or is it: thirded? fourthed? well, i think you have your answer.
btw: headsave is no more. Norm has closed up shop
it deserves more
's than that, but i'm tired. those that have classic's are holding onto them with iron fists
also: a "cheap" ppa is not $120 by any means. the cheapest i've seen them go for is $200 or so, i.e. out of your price range if you want to stick with $250 price range. the resounding statement here at headfi is: "can you increase your budget??????????", but i'm sure you'll be happy with what you get for $250, very happy i hope
emu 0404 and pimeta: excellent way to go for the $$$
Mar 1, 2005 at 4:40 AM Post #8 of 9
Thank you all... I was pleasantly surprised by the resounding nature of the response.
I think I will go fishing in the used amp pool and get something nice in the low hundred $s. What is the word on pimeta vs meta42?
Mar 1, 2005 at 4:45 AM Post #9 of 9
I would Definitely go 0404(this is key) and any AMP i could afford.
I strongly disagree with alot of people on this forum, the SOURCE is FIRST!!!!. After that even a CMOY will give you decent performance. I use the 595's and love them to no eend, they aren't hard to drive so a PPA isn't NEEDED but doesn't hurt.
I feel a PPA should only be used if you have the diamond buffer add-on, which by your budget, you don't, Get a Pimeta, it will give great sound.
Make the 0404 key to your desicion. Unless you dont' like stereo output.
