I've added to the ticket which is currently open for the tech team. As soon as I have any updates, I'll let you guys know. If you find any more issues related to this, please post them, and I'll keep adding to the ticket.
Unable to post ad in FS forums
- Thread starter rawrster
ljokerl
Portables Reviewerus Prolificus
- Mar 2, 2009
Just had the issue described above. "Submit" button on FS post did not work until the page was refreshed. Tried in Opera 10.10 and IE8 with identical results. Running XP SP3. Submit button also exhibits similar behavior on edits.
Can you guys give step by step instructions that I can pass along to the tech guys? They want to know the exact steps you're taking so we can re-create the problem as accurately as possible.
Permagrin
- Apr 24, 2009
I've been trying to post a reply in a thread for awhile now. The thread itself is not broken but the page never fully loads, stuck on 58/59 or whatever, EVEN AFTER REFRESHING (which recently would load the page properly to allow for posting). So just like before you can attempt to submit post but it hangs on the posting message dialogue box.
Permagrin
- Apr 24, 2009
Seems to be working better in Firefox. With Opera though most of the threads I frequent never load fully even after refreshing and thus do not allow posting as it hangs on submitting post.
Like I said in my previous post, in the last few days I would have to refresh every page after it loaded for it to fully load all of the elements because otherwise it wouldn't allow submission of posts.
Permagrin
- Apr 24, 2009
Seems to be working better now. Pages seem to be loading fully instead of stalling.
svyr
- Jun 8, 2009
Opera 12. Submit button on FS ads not working. (nothing happens when you press it at all...no loading box nothing.)
IE 9 and opera 12 - editing the FS ad in markup (non rich text) mode is broken... You can't type things - the cursor disappears and the field loses focus. To edit ads you need to type the markup somewhere then paste it in. (you can select everything then right click and paste it in
This has been going on for weeks and is simply inexcusable and.... Huddler are either severely understaffed, have a really %*#%&# release/testing process or are just a bunch of scammers.
I'd rather have the old but working system until they fix the new features they've recently added without the BS people using the classifieds section have to go through.
svyr
- Jun 8, 2009
[30/07/2011 11:22:59] JavaScript - http://www.head-fi.org/classifieds/listing/edit/classified_id/16318/forum_id/6550
Event thread: load
Uncaught exception: TypeError: Cannot convert 'a.one(e)' to object
Error thrown at line 9, column 1884 in (A, y, x) in http://yui.yahooapis.com/combo?3.3.0/build/yui/yui-min.js&3.3.0/build/loader/loader-min.js:
throw (y||new Error(A));
called from line 8, column 9752 in (z, w, x) in http://yui.yahooapis.com/combo?3.3.0/build/yui/yui-min.js&3.3.0/build/loader/loader-min.js:
this.error("use callback error",y,x);
called from line 8, column 11225 in (V) in http://yui.yahooapis.com/combo?3.3.0/build/yui/yui-min.js&3.3.0/build/loader/loader-min.js:
x._notify(A,T,y);
called from line 21, column 8181 in (Y, X) in http://yui.yahooapis.com/combo?3.3.0/build/yui/yui-min.js&3.3.0/build/loader/loader-min.js:
L.call(this.context,{msg:Y,data:this.data,success:X});
called via Function.prototype.call() from line 21, column 8819 in () in http://yui.yahooapis.com/combo?3.3.0/build/yui/yui-min.js&3.3.0/build/loader/loader-min.js:
Y._finish(b,c);
called from line 22, column 2113 in (a) in http://yui.yahooapis.com/combo?3.3.0/build/yui/yui-min.js&3.3.0/build/loader/loader-min.js:
l._onSuccess();
called from line 21, column 11091 in (Z, a, Y, X) in http://yui.yahooapis.com/combo?3.3.0/build/yui/yui-min.js&3.3.0/build/loader/loader-min.js:
this.loadNext();
called from line 21, column 11112 in () in http://yui.yahooapis.com/combo?3.3.0/build/yui/yui-min.js&3.3.0/build/loader/loader-min.js:
L._insert(null,null,K);
called via Function.prototype.call() from line 22, column 2072 in (a) in http://yui.yahooapis.com/combo?3.3.0/build/yui/yui-min.js&3.3.0/build/loader/loader-min.js:
l._internalCallback=null;
this.loadNext();
Error initially occurred at line 1, column 7704 in c(e) in http://www.head-fi.org/mini/1311980201/classifieds.js:
a.one(e).append($H.template("addImagesHtml"));
called from line 1, column 10565 in (e) in http://www.head-fi.org/mini/1311980201/classifieds.js:
return new c(e)
called from line 1, column 11429 in () in http://www.head-fi.org/mini/1311980201/classifieds.js:
var e=null,l=null,g=null,w=true,d=0,h=0,v=null,f=null,u=$H.imageUploader.getInstance();
called from line 1, column 11120 in (c) in http://www.head-fi.org/mini/1311980201/classifieds.js:
var b=(function(){var e=null,l=null,g=null,w=true,d=0,h=0,v=null,f=null,u=$H.imageUploader.getInstance();$H.editor.init({toolbar:"classified"});function i(z){c.one("p.error").set("innerHTML",z);return false}function p(){var D=null;i("");var z=e.one(".name input").get("value").trim();if(!z){return i("You must provide a name.")}var C=$H.editor.getData().trim();if(!C){return i("You must provide a description.")}var A=e.one(".type select").get("value");var B="0";if(A!=2&&A!=4){B=e.one(".price input").get("value").trim()}if(!B.match(/^(\d+,?)+(.[\d]+)?$/)){return i("You must provide a valid price.")}e.one(".price input").set("value",B.replace(/,/g,""));return true}function s(){var A={};e.all("input,textarea,select").each(function(D,B){var C=D.get("type");if(C=="hidden"||C=="submit"){return}A[D.get("name")]={element,type:C,tagName
.get("tagName"),value
.get("value"),checked
.get("checked"),disabled
.get("disabled")}});if(A["Classified[ship_to]"]){var z=e.one(".ship_to input[type=radio]:checked");if(z){A["Classified[ship_to]"].value=z.get("value");A["Classified[ship_to]"].disabled=z.get("disabled")}}return A}function n(B){for(var z in B){var A=B[z];if(A.type=="checkbox"){A.element.set("checked",A.checked)}else{if(z.match("body")){$H.editor.setData(A.value)}else{A.element.set("value",A.value)}}if(z=="Classified[type]"){if(A.value==2||A.value==4){c.all("#classifiedPrice").hide()}if(A.value==5){c.all(".ship_to").hide()}}}}function q(){e.all("input[type=text]").each(function(z){z.set("value","")});e.all("select").each(function(z){z.set("value",z.one("option").get("value"))});e.all("input[type=checkbox]").each(function(z){z.set("checked",false)});$H.editor.setData("");a=false}function y(D){var F={},B=[];for(var z in D){var E=D[z];if(z.match("best_offer")){F[z]=E.checked?" or best offer":""}else{if(z.match("tags")){if(E.checked){B.push(PARAM.tags[z.match(/\d+/)[0]])}}else{if(z.match("type")){F[z]=PARAM.types[E.value];F.ship_to_display=E.value==5?"none":"block"}else{if(z.match("ship_to")&&!E.checked){F[z]=1}else{F[z]=E.value}}}}}if(B.length>0){F["Classified[ship_to]"]=B.join(", ")}else{if(F["Classified[ship_to]"]){var A=F["Classified[ship_to]"],C=PARAM.shipping_options[A];if(A==2){C+=" "+F["Classified[ship_to_details]"]}F["Classified[ship_to]"]=C}else{F["Classified[ship_to]"]=PARAM.shipping_options[1]}}F.display=l.hasClass("history-visible")?"block":"none";l.append($H.template("historyEntry",F));d++;l.one(".title .num-items").set("innerHTML",""+d+" "+((d>1)?" items have":" item has"));l.setStyle("display","block");v.stop();l.one(".title").setStyle("background-color","#FFF9DA");setTimeout(function(){v.run()},3000);return l.one(".entry:last-child")}function t(){window.scrollTo(0,c.one("h1").getXY()[1]-8)}function k(D,B){var A=u;if(!p()){return t()}u.initUpload();var C;if(B){f=s();C=y(f);A.setEntry(C);var F=l.one(".title .loading");F.setStyle("display","inline");c.all("#edit-images").setStyle("display","none");u=$H.imageUploader.getInstance()}else{$H.loadingPanel.show()}function E(G){var H=(G&&G.message)?G.message:null;if(B){C.addClass("error");C.one("div.edit").set("innerHTML",((H)?"Error: "+H:"An error occurred")+" (please resubmit the form below)");h++;l.one(".title .error").set("innerHTML"," ("+h+" item"+(h>1?"s":"")+" failed)");n(f);i(H)}else{i(H);$H.loadingPanel.hide()}}function z(H){if(B){var I=C.one(".name .content");I.set("innerHTML",$H.template("historyName",{thread_url:H.thread_url,name:I.get("innerHTML")}));var L=C.one("div.edit");L.set("innerHTML",$H.template("historyEdit",{classified_id:H.classified_id}))}var J=$H.url("/gallery/image/add/album_id/"+H.album_id+"/hash/"+PARAM.hash+"/user_id/"+PARAM.user_id);if(B){if(PARAM.edit){var K=C.one(".photos .content"),G=c.all("#edit-images .classified-thumb");if(G._nodes.length>0){K.removeClass("notloaded");K.set("innerHTML","");G.each(function(M){K.append(M)})}c.all("#classified-id").remove();c.all("#edit-images").remove()}if(!A.hasImages()){C.one(".photos .content").set("innerHTML","No photos uploaded")}A.uploadAll(J,function(){A.reset()});if(w){e.all(".ship_to").show();e.all("#classifiedPrice").show()}}else{A.uploadAll(J,function(){a=$H.imageUploader.changes=$H.imageUploader.uploading=false;window.location=$H.url("/classifieds/listing/complete/forum_id/"+PARAM.forum_id)})}}c.io($H.url("/classifieds/listing/create/forum_id/"+PARAM.forum_id),{method:"POST",form:{id:e},on:{complete:function(H,G){if(B){F.setStyle("display","none")}},success:function(I,H){var G=$H.handleJsonResponse(H.responseText);if(typeof G.error!="undefined"){G.status="error";G.message=G.error}if(typeof G.status!="undefined"&&G.status=="error"){E(G)}else{z(G)}},failure:function(H,G){E()}}});if(B){g.setStyle("display","block");if(g.one("input[type=checkbox]").get("checked")){w=false}else{w=true;q()}t()}}function j(){l.addClass("history-visible");l.all(".entry").show();l.one(".title a").addClass("smminus");l.one(".title a").removeClass("smplus");l.one(".hide-show").set("innerHTML","hide")}function o(){l.removeClass("history-visible");l.all(".entry").hide();l.one(".title a").removeClass("smminus");l.one(".title a").addClass("smplus");l.one(".hide-show").set("innerHTML","show")}function m(){if(l.hasClass("history-visible")){o()}else{j()}}function x(A){var z=A.target.get("value");if(z==2||z==4){e.all("#classifiedPrice").hide();if(z==4){e.all("input.price").set("value","0")}}else{e.all("#classifiedPrice").show()}if(z==5){e.all(".ship_to").hide()}else{e.all(".ship_to").show()}}function r(z){c.one("#hiddenSubscribeSelect").set("value",z.target.get("value"))}return{init:function(){e=c.one("#new_classified_form");l=c.one("#classified-history");g=c.one("#copy-from-previous");e.on("submit",k);g.all("input, label").on("click",function(z){if(w&&f){n(f)}});v=new c.Anim({node:l.one(".title"),from:{backgroundColor:"#FFF9DA"},to:{backgroundColor:l.getComputedStyle("backgroundColor")},duration:1});l.one(".title").on("click",m);l.one(".title a").on("click",function(z){z.preventDefault()});e.one(".type select").on("change",x);x({target:e.one(".type select")});e.all(".ship_to input[type=radio]").on("click",function(z){if(z.target.get("value")==2){e.one(".ship_to input[type=text]").removeAttribute("disabled")}else{e.one(".ship_to input[type=text]").set("value","").setAttribute("disabled",true)}});c.one("#submit").on("click",function(z){z.halt();if(c.one("#classified-id")){_gaq.push(["b._trackPageview","/classifieds/listing/edit/complete"])}else{_gaq.push(["b._trackPageview","/classifieds/listing/add/complete"])}setTimeout(function(){k(z)},100)});c.one("#submit-and-add-another").on("click",function(z){z.halt();_gaq.push(["b._trackPageview","/classifieds/listing/add/complete_and_add"]);setTimeout(function(){k(z,true)},100)});e.all("#edit-images .photo input[type=checkbox]").on("change",function(B){var A=B.target,z=A.ancestor(".controls").one("input[type=radio]");if(A.get("checked")){z.setAttribute("disabled",true).set("checked",false)}else{z.removeAttribute("disabled")}});c.one("#subscribeSelect").on("change",r);r({target:c.one("#subscribeSelect")});e.all("input,textarea,select,").on("change",function(){a=true});c.one("#subscribeSelect").on("change",function(){a=true})}}})();
called from line 8, column 9732 in (z, w, x) in http://yui.yahooapis.com/combo?3.3.0/build/yui/yui-min.js&3.3.0/build/loader/loader-min.js:
z(this,w);
called from line 8, column 9472 in (B, A) in http://yui.yahooapis.com/combo?3.3.0/build/yui/yui-min.js&3.3.0/build/loader/loader-min.js:
B._notify(z,A,w);
z(this,w);
x._notify(A,T,y);
Y._finish(b,c);
What browser were you using when you received this message, and can you let me know what steps you took when get to this error?
svyr
- Jun 8, 2009
opera 12.
Err, I either edit or try to post a FS ad.
Pretty sure it happens when I press submit.
