jterp7
- Jan 2, 2006
personally I think the 5pros have plenty of bass and I listen to R&B and hip hop. that said, to feel the bass it still does not match a nice pair of logitech's with a subwoofer, which are consumer level.
I think the mids and highs, especially in classical music aren't quite as clear as my e3c's with my 5pros...let alone for the even heavier EBs. So long as you don't listen to classical at all I think you'll be good with the EBs if you are a bass fan. Otherwise stick with the 5pros, which do perfectly fine in the bass department and should be more balanced overall.
Originally Posted by devilsadvocate /img/forum/go_quote.gif The bass on the Pro is much weaker. Honestly, I prefer the EBs. I'm actually starting to consider selling my Pros. No idea. But generally Creative players tend to have good sound. I enjoyed my Vision: M before it got stolen. Cowon is better though, IMO. My take is that if you get the Pro you will really feel that the bass is too weak, especially if you want to "feel" the bass or if you're comparing to speakers. Final note: if you get the EBs, let the burn in. They will get much, much more refined after a week or so of use. And if you look at my sig you'll note that I own both. |
