michaelv20850
- Jul 1, 2008
Hi
I have UE Super fi pro. The cable jacket is clear. I see the cable inside clear jacket near the earphone turning green! Does it happen to you? I believe that UE is well-known but how can it happen to me? Is there anyway to fix it? otherwise i need to order another pair of replacement cable.
I probably go with another brand.
thanks.
thanks.
