qoouep
- Nov 30, 2009
First off: I know that it's best to leave all the volume controls on the computer on max when using a DAC.
However, when I use IEMs with my new uDAC, the right channel is significantly quieter than the left until the volume is above a certain level. I would prefer the volume to be quieter than that, but the only way to lower the volume while still maintaining equal volumes in both channels is to lower the volume on the media player or the Windows 7 sound mixer.
It seems to sound best when the Win7 Mixer is at max volume, the media player is very low volume (and then the uDAC is at the point where both the left and right channels are the same volume).
This system works, to a certain extent, but I end up tweaking the volume all the time and when other programs make sounds it is quite deafening. Is there a better way to do this?
