dsavitsk
MOT: ECP Audio
- Aug 3, 2003
Another project to look at (in addition to the pimeta and others mentioned here) is the Pete Millett amp. It is a little bit more expensive than the Pimeta to build, but it is also a bit easier, and I prefer its sound. http://www.pmillett.addr.com/hybrid_head.htm Pete used to run wheatfield audio, and his designs are being incorporated into Headroom's stable of amps. The Pimeta is not bad at all, but the Millett has a deeper warmer sound that you will likely like if you like your B&W's.
-d
Originally Posted by twodeko hah, probably a PIMETA next... not so sure, any advice? |
-d
