aQiss
- Jun 11, 2012
Yes, you're right. Almost all audio editors allow to do the analysis of the frequency range; that's the best way to tell if your files are lossless or lossy.
Check out the screenshot (Wavepad Sound Editor).
Though the frequency range does not tell you the whole story, as some of the encoders (e.g. HE-AAC, sample number 2) just compress audio details instead of removing the high frequences.
I was meant to ask if the differences we heard could be measured via headphones and plotted on a graph. Each bit rate would show a different frequency response in speculation anyway.
