ChrisOc
Congratulations...that looks so cool!
I am looking forward to your impressions.
Life with beautifully controlled fire that is good!I’ll do it for sure!
I’ll get some burnin and try it with my IEMs.
Also burning RS6, my life is always “on fire”
So there will be a question when it comes to EST, the place where to place the EST, and which kind of DD should be chosen. Thank you for the advice, we can make a prototype to have a try, but not sure to release it.DD (LCP or Beryllium coated) full range + Sonion EST tweeter
Waiting, waiting and waiting for your impression.I’ll do it for sure!
I also received mine. Does AMP need burning?I’ll get some burnin and try it with my IEMs
Different DAC chips may be responsible. The Hiby R5 uses Cirrus Logic and TK-2 uses Sabre. I very much liked the Cirrus Logic style of sound and when I first heard a Sabre chip, I thought it was a bit forward and analytical but now I just hear it as revealing.I also received mine. Does AMP need burning?
To my ears, my iems sound brighter with this TK-2 compared to my Hiby R5.
It pairs better with warmer iem such as ISN D10.
One thing quite bothers me is it seems less powerful than Hiby R5.
The plus is all ports work paralelly. You can do A/B testing from 2.5mm and 4.4mm, even 3.5mm if you want to.
Since the EST requires a lot of space, I would try to do it in a more unique way. Like having the iem stick out like the old Sony EX800ST/1000 shape.So there will be a question when it comes to EST, the place where to place the EST, and which kind of DD should be chosen. Thank you for the advice, we can make a prototype to have a try, but not sure to release it.
Really?Guys TRI TK2 is a real bargain, sounds amazing out of the box, I don’t have much time with it, almost 2h but I can say it a real steal!
OK.Without say name, far better than dongle at same prices and even better than some dap around 500/600$
I won't say it is better. It gives me more options of source because to my ears it sounds different from my Hiby R5 which is warmer.-- Better than any DAP of comparable price..
