Total Bithead and Batteries
Feb 22, 2008 at 11:20 AM Thread Starter Post #1 of 6
probedb
Hi folks,
I've not posted here in a long while and have a question about the Total Bithead.
When it's plugged into the PC via USB do I need the AAA batteries?
I want to buy one for work as I'm fed up of being able to identify different Windows apps from the sound the make on my UM-2s
It's likely always going to be plugged into the PC.
Will I still need batteries or can it be completely powered from USB? From reading various stuff I'm not 100% clear?
Cheers
Paul.
Feb 22, 2008 at 2:37 PM Post #2 of 6
When you plug the Bithead in to a USB it powers itself off of that, bypassing the batteries. You can flip the switch on to supplement the USB power with battery power if you like, although I haven't found this to be necessary you may want to do this for higher impedance phones.
Feb 22, 2008 at 4:03 PM Post #4 of 6
You shouldn't need it. I only needed to turn it on once. I was trying out my roommates pair of 600-ohm AKG240 cans and even with high gain the USB couldn't pump out enough juice to make respectable sound. The batteries helped a bit, but I'm convinced that those headphones are too inefficient for my sytem right now.
Feb 22, 2008 at 7:19 PM Post #5 of 6
Originally Posted by probedb /img/forum/go_quote.gif
Cool thank you, I was hoping for that
I don't think the UM-2s are that hard to drive?
My first portable headphone amp and IEMs were that exact set up. No problems at all just straight from USB.
