Topping D90
Jun 4, 2020 at 5:40 PM Post #331 of 1,101
Well the d90 is as I said before a magnifier of source, wires; Etc anything you connect to it. Today I decided to try my old Sony CD player coax out and compare it to WAV files on my pc using usb out from cpu to d90. No words can tell you how much better the CD player sounds playing exactly same track. And hd tracks streamed from tidal and amazon have great sound BUT when you compare them to spinning the disc omg
It’s like instant coffee vs ground fresh bean. I just fell in love with my D90 all over again and my old cds. The D90 reveals all the details - amazing quality at any price.
Jun 4, 2020 at 5:42 PM Post #332 of 1,101
Thanks for the response, which one sound better to you? Can't tell the different on my set up
I always prefer the DAC mode when available, but if you can't tell the difference, use the option that is more convenient to you. I always like to say, 'if the difference is so subtle that you have to A/B to detect inappreciable difference, then it's not a difference worth pursuing, let alone mentioning.'
One thing I did notice is the linout on A90 didn't sound good at all. I had terrible hissing/static/distortion. Tried several different cables and that wasn't it.
Jun 4, 2020 at 5:58 PM Post #333 of 1,101
@goone
If you use other devices to control volume -> DAC mode.
If you use your DAC to control volume -> PREAMP mode.
Jun 5, 2020 at 3:56 AM Post #335 of 1,101
Hi all, which amp is suggested as a pair to D90, under 250$? Headphones to be used are 6xx and lcd2c.
Jun 5, 2020 at 11:37 AM Post #338 of 1,101
Here's my take on the D90, it is a truly superb DAC for the price:
https://www.head-fi.org/showcase/topping-d90.24402/reviews#item-review-23781
Jun 5, 2020 at 5:23 PM Post #339 of 1,101
Shame the preamp is mediocre, but that's usually the case for most all in ones. Best to use as DAC only mode and use the Windows volume control (as a temp solution) or get JBL nano patch+ and etc.
Jun 5, 2020 at 5:30 PM Post #340 of 1,101
I would assume that this is a minor or non-issue for most here who are primarily or (like me) exclusively using a DAC with headphones. If you're using the D90 in a speaker system, it's a different story.
Jun 5, 2020 at 5:36 PM Post #341 of 1,101
LIneout on D90 is perfectly fine. It's the RCA connection between D90 & A90 that is the problem. Using RCA interconnect makes both HPA/PRE on A90 unusable. Another user claims XLR interconnect solves that problem. I'm gonna have to wait till Monday to test that.
Jun 5, 2020 at 5:38 PM Post #342 of 1,101
Yes, I use it with speakers (balanced amp) 95% of the time and only recently started playing with other passive preamps and couldn't believe how even the Windows volume controller sounded superior to the built in.
Jun 5, 2020 at 6:42 PM Post #344 of 1,101
I had this exact problem when I tried RCA between D90 and A90 yesterday - no sound out of headphones or pre. It drove me crazy for a good 30 minutes. I turned both the units off from the power switch on the back, ensured connections were correct, ensured A90 was set to RCA, turned the power switches back on, turned A90 toggle to hpa, heard a click - and then everything worked as expected...
Jun 5, 2020 at 7:26 PM Post #345 of 1,101
For me, it was more of an unbearable noise issue on RCA interconnect, although I did have connection problems on PRE mode on A90, where it didn't work sometimes and required a reboot. Anyways, I'm returning my A90 tomorrow for a replacement unit. I'll give it one more shot before I move on to another HP amp. I want to keep them as a stack for aesthetics, but will look else where if problem persists. I do love the D90 though. I think its in the perfect sweet spot in terms of price to performance. I will never again pay $3K~$5K for a DAC/AMP. I've learned that for me (YMMV), when it comes to DAC/AMP, getting something that doesn't break the bank and measures extraordinary well, then spending the extra money on headphones is the way to go.
I've purchased the Topping stack thru APOS and their customer service has been nothing but stellar. Prompt response and great service. I wouldn't hesitate to use them again in the future.
