riton66
- Mar 25, 2010
I see 2 main differences from the previous pic.
Sorry for the picture quality..
It's the XMOS drivers, the 3.34 ones that are recommended in the thread are not right, using the drivers downloaded from the topping website (2.26) makes the sound almost equal switching from spdif to USB (warmer and with a right tonal balance), so I was misjudging the sound, now it is much better, before it was like scratching nails.
As I mentioned earlier, here are the caps I used in place of the 4 black "CapXon" 220uF electrolytic ones:
2 Nichicon KA 470uF/25vdc (hndme.com 3-KA-470025R0) for the 2 that are close to the voltage regulators
2 Nichicon KA 330uF/25vdc (hndme.com 3-KA-330025R0) for the 2 elsewhere
These are long-life, high-quality, high-temp (105C) units which fit inside the case. (The Elna's I bought first were too large for this case.)
Like I said before, I've already seen stock D30s with larger-than 220uF caps in those same positions. They did rate these 220uF caps for 105C temps (for longer life), if their labeling is true.
Anyway, at the very least, I would have had to change the ones close to the v regulators. The added power draw of the Sparkos (which runs in class A at times) made it prudent, more so with the case being totally closed. The case does get hotter than before but never past 90F on the outside (room @74F). The Sparkos itself never went over 90F (open air) while playing. However, there are areas on the board that did climb to 104F (open air).
So, if your 4 black caps are 330uF+ you may not need/want to do anything. Then again...every time I've upgraded caps elsewhere -- aside from signal path -- good things happened eventually. More so if the PS components were getting the attention. Unfortunately, I had to ship this D30 unit out before I could give the new caps time.
Would anybody have a schematic of the d30? I have been using it now for about 6 months, and was working perfectly well - a couple of days ago it simpy stopped mid stream ( I mean the audio out stopped)
Windows still recognizes it, and even shows as if it is playing a test tome through it - so at least the USB part is active and showing signs of life.
I want to do some diagnostics before I go swapping parts - I'll try to claim on warranty, BUT still would be good if we have a diagram or 2 to help with diagnosing. I suspect that the test points will prove very usefyl, provided there is sufficient information on what to expect on each.
Vlad
there is high pitch noise when I crank up the headphone amp - so even though not moded, I may be experiencing some osicilation ( I can hear it so it is under 12 khz - the limit of my hearing ).
No Osciloscope, But I'll measureany DC conditions first - will be fun. Not desoldering anything just yet - will see the response on the warranty first.
I'll definitely check the negative voltage one - assuming I have an oscilating opamp.
yup. en.tpdz.net
