haha... I don't know what that means.. but since you have figured out your problem, that's all that matters...
Topping D30 DSD DAC XMOS/CS4398
- Thread starter drteming
at the moment the dac is only working with my laptop. nativ dsd files are no problem.
K Roland_61
Hi,
I have noticed that Foobar2000 needs a lot of RAM memory to run flawlessly??
For 2 times the system "froze" while running Foobar2000. All the programs stopped, including F2K. Anyone confirms it? My laptop has 8GB of RAM installed.
Thank you all.
Thank you all.
- Nov 11, 2004
Hi,
Thank you all.
All 3 of my systems run foobar 2k and my two primary listening systems have 4GB. Never run out of memory or freezing in years of use. I would look to other setting to see what is using the memory. And other issues to see what is causing the freezing.
no Problems at all.
Do you have done a New installation.
K Roland_61
The only thing I did was to set the "buffer length" from 1000ms to 1500ms for tests, but I'm not sure if by doing that the system could "freeze".
Buffer length is back to 1000ms...
Feilong4
About to order a D30, but I have to ask: Does it come with an RCA cable?
Edit: Whoops, I'm dumb. I just looked at the first post.
the usb stick is also missing. you have to download the drivers of their homepage.
Feilong4
Ah, thanks for letting me know!the usb stick is also missing. you have to download the drivers of their homepage.
hiThe 2009 and 2023 version had been branded by their respective vendors, but worked well. The 3072 version (from the private message) was the stock XMOS version without modifications and also worked well.
this is the last version of the driver ?(3072)
yes, XMOS-Stereo-USB-Audio-Class2-Driver-3072_v3.34.0
https://www.head-fi.org/threads/topping-d30-dsd-dac-xmos-cs4398.821559/page-6#post-13247636
viveksaikia22
I hooked up the Topping D30 to my MacBook running Audirvana Plus and tried to stream DSD audio from Tidal but no joy. I tried to follow the below steps to enable DSD but the "To DSD" option is not enabled -
https://audirvana.com/?p=4015
Has anyone tried the same setup and is able to stream DSD audio from Tidal in Audirvana Plus?
Hello,
It might be a weird question, but did anyone try to hook up D30 to either Tv to listen/watch NETFLIX stream or to the xbox ONE S ?
I have a very bad experience with Wolfson WM8524 based DAC on these sources, even when I set stereo output on xbox S/PDIF.
So, my main doubts are:
1. Will D30 work well with NETFLIX and xbox ones?
2. Could D30 down-mix multichannel sources to stereo automatically?
thx
Andrew
thx
Andrew
simon740
Hello,
Can I ask wich INPUT (usb or S/pdif)) on D30 is better implemented ? I'm deciding for a new transport - Allo Sparky Usbridge or Allo DigiOne.
So I'm wondering what's better on the D30 (USB or S/pdif).
regards,
Simon
regards,
Simon
look here
https://audiosciencereview.com/forum/index.php?threads/battle-of-s-pdif-vs-usb-which-is-better.1943/
conclusion: Here the difference is quite pronounced. S/PDIF has noticeably higher noise floor to the tune of 13 to 14 db! So if you are worried about noise, S/PDIF interface has more of it with this DAC.
