redrich2000
- Oct 31, 2005
Planning to use my Fiio M11pro as DAC for Topping A90 amp. Will it do justice? Or Should i buy a dedicated DAC? I'm going to use it for Sennheiser hd800s
Are there any benefits of using Line Out 3.5mm to RCA over 4.4mm to XLR? Is 3.55mm still better because thats the designated lineout for Fiio m11 pro? Or can the 4.4 port work as line out as well? Just max out the volume?
I currently have my M11 connected to my A90. I want normally be doing this, just wanted to test the M11 DAC against my Eitr>Mimby stack. What I can confirm is the USB DAC out of the M11 is VERY noisy. If using this permanently, I'd say you'd need something like the ifi usb-c noise reducer. The Eitr>Mimby is definitely the better DAC too, as it should be but it's pretty close.
