jlemaster1957
@Currawong- first I want to say (for those who may not know your work) how greatly I have appreciated your reviews on YT as a subscriber to your channel. After listening to your review I purchased the CayinC9 portable amp and , N6ii DAP. It’s one of the wonderful things about being on Head-Fi that the top reviewers in the hobby are posting on these threads.If you're to going to go down the R2R route, then, IMO, I'd get a DAC/amp from Audio-gd, or separates from them, depending on your budget.
So, I just listened to your review on the Audio-Gd R27HE (who also make the Master 9 and 10 amps), which is an integrated amp that includes Audio-gd R8 DAC and Master 9 amp, and cost of which (R8 Mk2 I mean) is about the same as the Gustard R26. If I have understood correctly, many elements are similar between the 2 units, though each has its own distinctives (R26 has a pre-amp stage and has ability to stream LAN signal/Roon directly to its internal I2S circuitry, R8 seems to have superior power supply, internal clocking plus its proprietary ACSS bus). I very much like that Audio-Gd had its service center in Georgia in the US, so that if there is a warranty issue the unit does not have to be sent back to China for repairs.
Since this is the A90D thread, though- given the limitations of the A90D, and assuming that most readers are likely to be users of mid-fi gear eg wrt headphones HIFIMAN Arya, Audeze LCD-X etc- what particular separate Audio-GD R2R DAC would you most recommend to pair with the A90D?
