Topaz Low-Capacitance Isolation Transformers - for Affordably Clean Power
Dec 14, 2023 at 1:15 AM Post #557 of 569
Jan 12, 2024 at 10:39 PM Post #559 of 569
I followed this thread from the beginning and I could never find a big topaz with reasonable shipping to where I live in hawaii. A cheaper alternative that ships in a USPS large flat rate box is this antek 1000VA balanced isolation transformer.. it probably doesn't have the low capacitance interwinding that makes the topaz units extra special but it's a cheap way to dip your toes in the balanced isolation transformer pool.. I use it with my desk system and audiogd di20/eversolo dmp-a6 with linear psu upgrade, low power class A speaker amp with no issues.. seems to make it sound a little better https://www.antekinc.com/bp-1000-balance-isiolation-power-supply/
Jan 12, 2024 at 11:43 PM Post #560 of 569
Jan 13, 2024 at 1:16 AM Post #561 of 569
LOL thanks oneguy for the ebay auction with free shipping to hawaii. but usually they say "oh I forgot freight to alaska or hawaii is $300"
Jan 13, 2024 at 1:27 AM Post #562 of 569
No worries, just trying to help out and I figured the worst they could do is say no. As they say “a closed mouth doesn’t get fed”
May 18, 2024 at 6:52 PM Post #563 of 569
Balanced wiring happens on just the output side but the input side will need to be changed from the 120v wiring setting. You wire the input side for 240v (jumper H2 and H3) and wire the output side for 240v (jumper X2 and X3). The balance wiring comes in when you wire X2 or X3 (it doesn’t matter which one) to ground.
Balanced wiring diagram:
-The 240v setting on the output side allows you to have a center tap (X2 or X3) to ground which you need for balanced power.
-The 240v setting on the input side side allows the input side to be 1:1 with the output side (both sets of input coils and output coils are now in series in the respective sides). If you left the input set up for 120v this would cause a step up in voltage.
-Grounding the center tap allows the wave forms to be halved thus creating two 60v sine waves 180 out of phase with each other.
Hello oneguy. I've read through this entire thread and I still have a few questions one some things for wiring for balanced. I have a terminal equipped 2.5kva 0.0005pf MGE. I've wired it as you mention so far but here's a few questions: Are you supposed to run a wire jumper on the ground on the *input* side over to the jumpered H3 & H2? Is the input equipment grounding conductor going to the power cord supposed to actually be wired to the input ground or to the jumpered H3 & H2? The thing that makes me wonder about this, is that on the input side, unlike the output, there are actually 2 ground wires, there's a chassis ground, and there's also another ground that runs internally to the transformer itself, whereas on the output side, there is only a chassis ground. Correct me if I'm wrong, but it seems to me that if there's a ground running directly to the transformer that should be grounded through the power cord to the wall, or does it matter? I had already wired this up and tested it with no chassis grounding on either the input or output (no ground wire jumped over to the jumpered X3 & X2 center tap). I got the correct measurements on a multimeter and even powered up a monitor with it. I have both grounds running off of the jumpered center taps on both input and output--if this is definitely wrong, like for the input, let me know.
Thing that concerns me though (and I'm wondering if this is because I haven't grounded what I need to) is that as soon as you power this on (I do it from a breaker in a panel) the breaker I tried this on as an arc-fault circuit interrupter, and it immediately freaked out and cut the power, refusing to allow it to be turned on (is this because the ACFI is seeing current on the neutral?). The only way I could actually power this up to test it was to plug it into another iso transformer which 'hid" it from the ACFI circuit. What's weird is that I have a different brand audiophile balanced power conditioner that does not cause an ACFI breaker to trip, so hopefully that gets straightened out or I'll have to get rid of the breakers.
May 19, 2024 at 1:44 AM Post #564 of 569
No, no terminal from H1 through H4 should be grounded.
Input ground.
You are correct. The transformer should be grounded through the wall.
None of the taps on the input side should be grounded. On the output side, only the X2 or X3 should be grounded. I have attached pic below to illustrate the wiring.
White is neutral, black is hot, the short black lines from H2 to H3 and X2 to X3 are jumpers, Green is ground. Does that clear it up?
EDIT: to be certain that the above is not misconstrued, on the output side both lines are actually hot and carry voltage. I only mention colors and hot vs. neutral for wiring purposes.
On the output side:
-jumper to X1 should be about half of input voltage
-jumper to X4 should be about half of input voltage
-X1 to X4 should be about input voltage.
May 19, 2024 at 11:00 AM Post #565 of 569
Thanks, I got it wired correctly, performed all measurements, Made sure H1 and H4 resistance measurement to the case ground read as an open circuit as you had emphasized in a previous post. Installed and running perfectly. Having previously had H3&H2 connected to the EGC was probably what was causing the AFCI breaker to cut all power, lol, because it does not do that now. Like I said though I did have it temporarily powered up for about an hour with the input center tap grounded & plugged in another iso tranny so it wouldn't trip the AFCI, and I didn't notice any ill effects and it still measured 60v on the output from both hots to center tap. Hopefully I didn't damage anything with it like this? But it appears to be all good now wired correctly. I actually already implemented exactly what you said before I read your post, (based on deductive reasoning and further analyzing things) and thank you for taking the time to respond, confirming the correct wiring. The thing is pretty incredible at noise reduction. I have a line emi meter, and one circuit on a different iso xformer where my extremely noisy PC is plugged into it (the secondary of that xformer is blocking 99.99% of that noise from backfeeding into the mains) - but on it's secondary, there's 1500+ mv (1.5+ V) of noise circulating around there and the 0.0005pf MGE drops that down to around 80-90 mv with no output filter cap even (and this was before I had the grounding wired correctly--so it may even be better now).
Thanks oneguy for your assistance.
Edit: I have the H1 and X1 as black and H4 and X4 as white, but does it even matter either way, as long as both are the same from primary through secondary? A previous post you stated:
"Black to H1, white to H4. Black to X1, white to X4"
May 19, 2024 at 11:39 AM Post #566 of 569
I’m glad everything is working correctly and you’re enjoying the isolation transformer. The EMI drop between primary and secondary is quite good as you noted
Nope, the transformer will be fine. This wouldn’t have created any damage to it.
Yep, correct. H1/X1 can be black and H4/X4 can be white or the opposite (H1/X1 can be white and H4/X4 can be black). It doesn’t matter.
May 27, 2024 at 11:31 AM Post #567 of 569
One other question I had. On the output side, there are 2 thinner black wires coming from inside the left and rightmost side, that when previously wired as 120 in and out, have been connected to X1 and X4--what are these wires connected to internally? Is there a hidden cap inside or is this an electrostatic shield connection on the output side? I've left those 2 wires the same as they were before, as there was nothing to indicate a change was needed with them. Do I leave these alone or change their configuration as well?
May 27, 2024 at 1:29 PM Post #568 of 569
Most likely the capacitor. I’d need a pic to say that with more conviction. Send me a PM.
Aug 21, 2024 at 1:23 PM Post #569 of 569
Square D sold their isolation transformers under different names, including ECA. Does anyone know if these brands also made .0005 models? I bought an ECA 500va for a great price. It makes a huge sonic difference in my system. It removes a range of peaky grit in the upper mids and highs that I've been plagued with for years. I am looking at Topaz .0005 models now. It would widen my chances if other brands; offered the same thing.
Surprised the iso transformer makes such a big difference. I live in the country, about 1.25 miles from the substation. Have no neighbors and my own pole transformer is ~30 ft from the electric box. A dedicated 20 amp lines feeds the audio system. The music is so much smoother with considerably more depth. Amazing.
Thanks,
barondla
