mowglycdb
- Nov 29, 2011
Some people talk without knowing, and a lot of times it's cause of the jelly of not having a high end equipment.
Yes it's about the same as with an amplifier. Except making clean line level output is even easier than making a clean amplifier or DAC. Most current solid state audio components are audibly transparent. The best reason to choose one over another is features and power (in the case of an amp).
Saying that solid state amps is extremely vague there's ss amps that sound like tubes.
For one thing, listener B in the study is used to a standard of equipment that very few individuals in even the high-end forums would be able to afford.
For another, many reasonable participants in sound science threads have owned (or still own) unobtainium gear and have been in the land of collective delusion.
you need a good hearing memory to be able to compare between equipment
Perhaps what he meant to suggest was that some solid state devices approximate low-fidelity tube sound through the use of parlor tricks? If so, I suppose we can call those defective by design?
This is my listening room / theater. The speakers have been upgraded since this photo was taken. The mains are JBL Towers and custom made 12 inch 5 way studio monitors from the late 70s. The center channel and rears are Klipsch, and the sub is the top of the line Sunfire. I use a Yamaha AV receiver, a Sony blu-ray player and a Mac Mini media server with over 75 TB of online storage. The server streams music all over the house using an Apple Airport Extreme. My system is calibrated to a flat response covering the full range of human hearing. It's taken me 30 years of trial and error to get to this point.
I guarantee you that you would be hard pressed to find better sound than this. My speakers are VERY expensive. My amp and players aren't. But the thing that really makes the difference is the time I have put into calibrating the EQ. Money can't buy the improvement proper application of room acoustics and EQ gives.
Happy to provide more details on my system if you are interested. If you are ever in LA, I'd be happy to demo it for you.
The only example of this I know about was "Bob Carver's challenge". Most amps don't deliberately hobble sound like that. The vast majority of them are designed to have a flat response, inaudible levels of distortion and a noise floor low enough to not be audible even at the loudest listening levels. You can pretty much go to Amazon and choose any midrange receiver and it will be able to do that.
