bcwang
- Feb 28, 2003
I was wondering if anyone knows the appropriate time to use the different Gain settings on the Tomahawk. Ray's site says the "high" gain setting is for driving all low impedance headphones, and "low" is for driving IEMs.
For IEMs I can understand using low because otherwise it is too loud before the channels become balanced. However, I'm getting conflicting ideas on what to use for full size headphones.
My understanding is the volume control adds distortion, so the more you can get the volume control out of the way, by raising it close to 0 attenuation the better. So this would mean it is best to leave the gain at "low" all the time unless max volume is not loud enough, then you would switch it to "high" and get additional volume. However, I've read from many that gain of "high" is more dynamic and sounds better, this contradicts my original theory.
-So does the gain actually change something else that makes the sound different in the tomahawk?
-Based on Ray's literature, does the tomahawk not drive "high" impedance phones well? What is considered high impedance?
-Should you use low or high gain if both can reach the desired volume on your headphone?
