rumatt
- Sep 24, 2006
I am thinking of building a very simple passive preamp. I want:
- A high-quality potentiometer or attenuator
- A high-quality toggle switch to choose between two inputs
- An input that bypasses the toggle in case I want to plug in direclty
That's it, so it should be very simple, but I'm pretty confused about the whole idea of a shunt resistor, and how to wire it.
1) If I buy a high quality attenuator (DACT maybe?) do I still need to use a shunt resistor? Chu Moy's writeup says you do not, but I don't know what they mean by "high quality". The Luminous Audio Axiom uses a Noble pot and a shunt resistor.
2) I don't understand the wiring diagram in Chu Moy's writeup. He has three wires connecting to the pot? I thougth the pot and resister are in series with each other, and together connect the lead and the ground in parallel with the preamp output.
3) Any ideas where to buy a high-quality toggle switch? I'd love to find a single site that sells all the stuff I need (Switch, attenuator/pot, some good wire, and a good resistor).
Thanks!
EDIT: Another option would be to just build a switch box and use two of these inline attenuators on the inputs to the amp.
Thanks!
