- Aug 2, 2008
Yes. Gungnir hits hard. One of the hardest hitting DACs in terms of lack of compression on the top scale of amplitude. Gungnir does not allow me to sleep. That can either be a good thing or bad thing.
Eeek - I should think this through properly then. Chances are low but will put some effort to see if I might be able to audition the Gungnir.
Thanks for the feedback, purrin.
Many times I have relaxed in the easy chair listening to Al Marconi on the LCD3c and the music completely carried me away into dreamland. If the music is relaxing that is what I hear. If the music is rock or metal it definitely is super energetic which I love. I regularly listen to meditation recordings and end up falling asleep every single time. Vocals just beautiful as well. Highly recommend the Gungnir. YMMV of course...
LOL, don't let my comment on the Gungnir dynamics scare you away. I've never fallen asleep at a RL concert or musical performance of any sort. So to me, the Gungnir is accurate in that sense.
Thanks for the reassurance guys, much appreciated. Know that your feedback will help someone live his daily life better.
I will give the Gungnir serious thoughts then - Might be hard to get someone to allow me to audition the Gungnir while I am on my bed (lol), but I will give it a shot.
Now that you are assured, let me cause some doubt The Gungnir can be aggressive sounding with maybe too much bite and harshness when used with certain bright headphones like the HD800. I don't use HD800 that often, and when I use the HD800, I use the Anax mods, so it's not an issue for me. I rather like to hear the bite, crunch, and harshness of certain instruments, so long as there are not artifacts added to it. The Gungnir is definitely a rock arena type of DAC. Doesn't mean it can't be used for classical either; it's not the most detailed DAC out there, but it's in my top five in terms of vocal rendition.
Pfftt oh purrin you.
But in all seriousness, I can't thank you enough. Can see where you are coming from. No worries, your impression (as well as the rest, thanks guys) will help me set benchmarks and know what to look for when I come across the Gungnir and Lavry DA11, won't buy blind.
I will be using my HE-560 with pre-production pads (on the Violectric V200 - which I know you find dynamically compressed, purrin)
Well, failing that, there's always the Audio GD Master 7 and a very upset wallet..... Heh.
As do I.
How does it sound with your GS-X2? Still happy or thinking of a upgrade?
Btw, I have the wyrd on it's way. Can report if I gain anything from adding it in front of the x-sabre.
